Phyliss
    55
Phyliss last won the day on June 13 2015
Phyliss had the most liked content!
About Phyliss
    West Sussex
3,047 profile views
  1. As mentioned the freewheels have two indentations, that if struck with a suitable punch, should start unscrewing. Prior to this there should be a collar that is undone the same. Rotation wise if the shaft is clamped vertically in a vice ( on an area of the shaft that isn't used as a bearing surface) the collar will be uppermost. This & freewheels come off anticlockwise from looking down on the shaft end. In between the freewheels is a plastic cover and possibly two shims. Assembly wise I don't think my method is right but I tighten them up with a suitable drift against a tooth of the sprocket. Writing on the sprocket should face you as you wind them on. Hope this makes sense.
  2. The chain jamming is the first issue that draws your attention to the rest of the drive. The mower goes forward but won't pull backwards. Generally the bush behind the gear wears allowing the shaft to be baggy resulting in a slack chain. No tensioner is fitted so a new chain is required. Also check the cover hasn't worn.
  3. The Hayter 56 (type 340 I think) had the circlip holding the sprocket on. If it doesn't shift with pry bars a little heat may be required but with the risk of damaging the bronze / plastic bush behind. In the past I have cut away the sprocket as close to the shaft as possible. Once the sprocket is off you should find a thin half moon key that transfers the drive. These can also be a pain to get out.
  4. Phyliss
    AN OLD RESTORATION
    I have found a later photo of the tractor! After googling "1954 BMB President" one of the pictures led me eventually to VPG 581. Looking at this picture deepened my thoughts as I recognised the location & exhibit number sheet to be the Cuckoo Fayre held in May at Laughton near Lewes, West Sussex. Another google search "1954 BMB President Cuckoo Fayre" shows it (on my computer) as the 2nd photo. Possibly a SEVAC member now owns it? Photo taken May 2011
  5. Hello Chris, I just had a look at "Briggs Bits". Entered your model number and a few parts pages are available to view. Had 296824 for the coil (possibly old number) & 29861 for the condensor. Best have a look yourself to confirm.
  6. Phyliss
    AN OLD RESTORATION
    Lovely restoration Alan. Have done a vehicle check & it's taxed (£0 to pay) till 1st December 2017 so still on the road somewhere. Registered September 1954.
  7. I spent most of the morning getting the Fordson winch tractor organised, on the trailer & made it nearly there but my Major had a few issues so had to turn round & head back. Stationary engines are now loaded & on there way shortly ( & hopefully)
  8. Phyliss
    Phyliss
  9. I'm not sure. I'll have to do some research although i believe the RAF sometimes used the Industrial spec model N, some with lighting & drum brakes etc. This one may just be a winch tractor for tree work etc but with the date on the winch (if that's what it is) dated May 1944 & the tractor a similar age, give or take a month, it may have been with the RAF or similar.
  10. Looks like a good show Chris with plenty of variety in your section. I haven't been for about 20 years when I used to attend with the family & stationary engines. I might have to look into bringing the RJ next year. Philip
  11. It's had a bit of a wash today followed by a spray of diesel to 'enhance' the rust Todays push / pull vehicle was my Fordson Major, which being dated to 1954 makes it only 10 years newer than the N. Some where in between the two came the E27N Fordson (1945 to 1952). Unfortunately the O/S/F tyre didn't stay on the bead but did stay on the wheel. Re-positioning the bar got it moving in the right direction but did bend the bar. The bluey green isn't the correct colour for the N as it should be green throughout (excluding the wheels) but if i can get it running it may be left as is for a while. The offside wing was also loosened to allow it to pivot back round into its correct place. Now the drive chain & gears can be seen. Having left diesel in the bores to loosen the rings the next job is to fit new front tyres & tubes & possibly strip the carb' to stop it flooding. Philip
  12. I should be there also. Not sure what with but have entered my Fordson Major & stationary engine & mill. I may take other stuff depending on time etc Very good show. Philip
  13. Phyliss
    The herd
    You certainly have a nice collection. That Cub looks nice as does the Suburban, very nice
  14. hi Tom. Yep got it back ok; apart from busting a ramp off the trailer whilst unloading. I didn't like them anyway & will look out for some removable ones or make some. It was being a bit of a monkey trying to push it round a corner due to the worm & wheel back end but we did it in the end. The tractor certainly does look better in daylight. I'm hoping it looks better still after a wash off.
