Ian 2,417 #1 Posted July 26, 2014 Here you are James The basic duel adapters are very easy to make. I can't remember the measurements as they were made many years ago, but allow an inch gap between wheels, so take that into account when you do the measuring.. The basic adapter was made from a strip of thick-ish steel rolled round so it fit's tightly on the inside lip of the wheel.. All it needs are four long coach bolt's to go through the four wheel weight holes to hold the second wheel in place I did take things a stage further by turning the duel wheel adapters into duel wheel wheel weights. Add a base. A "notch" for the tyre valve. Four tubes were added for the coach bolts to run through. Then the other side was capped off. A hole was the cut one side. And the adapter/weight was filled up with concrete using a lamp shade as a funnel Once the concrete had set, the metal that was cut out to fill it was welded back on.. Two Duel wheel adapters/wheel weights As fitted with only one wheel.. Just undo the nuts, slide the second wheel on, and put the nuts back on Ta Daa 1 pmackellow reacted to this Share this post Link to post Share on other sites
diggerjames 543 #2 Posted July 26, 2014 Cheers Ian that's great I'll get on with them when I get home mate cheers James Share this post Link to post Share on other sites
Ian 2,417 #3 Posted July 26, 2014 Your welcome James, one thing I should of mentioned is don't make the adapters too tight a fit in the wheel or they will be a right pain to get back off again... You can guess how I found that out Share this post Link to post Share on other sites
Robins 55 #4 Posted July 26, 2014 I like them Ian Custom dual wheel adapter/weights, theres just so many things to make for my tractor you are a bad influence 1 Ian reacted to this Share this post Link to post Share on other sites
nigel 1,876 #5 Posted July 26, 2014 ive got some duels that could be up for grabs Share this post Link to post Share on other sites
Ian 2,417 #6 Posted July 27, 2014 I like them Ian Custom dual wheel adapter/weights, theres just so many things to make for my tractor you are a bad influence Happy to help ive got some duels that could be up for grabs bay 001.jpgbay 002.jpgbay 004.jpg I forgot you had those tucked out the back Nigel, what did they come from? Share this post Link to post Share on other sites
Wristpin 400 #7 Posted July 27, 2014 The dual set up with weights certainly looks the part but I would guess could be a bit hard on the half-shafts particularly if used with that blade on the front? Share this post Link to post Share on other sites
nigel 1,876 #8 Posted July 27, 2014 Happy to help I forgot you had those tucked out the back Nigel, what did they come from? bolens Share this post Link to post Share on other sites
Stormin 4,458 #9 Posted July 27, 2014 bolens He only asked! 1 nigel reacted to this Share this post Link to post Share on other sites
meadowfield 1,900 #11 Posted July 27, 2014 That's an interesting setup Nigel... Share this post Link to post Share on other sites
Ian 2,417 #12 Posted July 28, 2014 The dual set up with weights certainly looks the part but I would guess could be a bit hard on the half-shafts particularly if used with that blade on the front? I never has any problems with half-shafts even when using the blade very hard pushing dirt about and that was when the Wh still had it's original trans with 1 inch diameter shafts! bolens I should of guessed that Share this post Link to post Share on other sites
