slf-uk 914 #1 Posted August 28, 2014 I have this week off work with lots of outside jobs to do. This morning it was raining and as I was not feeling great I decided not to get wet. Instead I went into the workshop looking for a small job to do and I decided to look at the D-160. I rebuilt most of the mechanics about two years ago and then dumped it in the corner, so I decided to re-commission it. By the time I had it running the sun was out so I took it for a run. The exhaust stack from a full size tractor (can't remember which one) makes it sounds great with no fumes for taking the boy for rides. After taking it for a run it went back in the workshop and I got a Bolens out to do some real work The real reason was the D-160 does not currently have a hitch fitted and I can't remember where I put it. Iain 1 Triumph66 reacted to this Share this post Link to post Share on other sites
pmackellow 2,728 #2 Posted August 28, 2014 Ah well if its getting in the way you had better let one of the other Wheelhorse fanatics give it a home... Only joking, nice tractor Share this post Link to post Share on other sites
diggerjames 543 #3 Posted August 28, 2014 It would look good at the side of My D200 ! Nice machine by the way ! Share this post Link to post Share on other sites
slf-uk 914 #4 Posted August 28, 2014 I have a D-200 too, currently waiting it's turn for some love. Iain Share this post Link to post Share on other sites
meadowfield 1,900 #5 Posted August 28, 2014 Norfolk the place to go for D series then Share this post Link to post Share on other sites
slf-uk 914 #6 Posted August 28, 2014 Two here now. My D-200 came from Durham and the D-160 from near Luton. Iain Share this post Link to post Share on other sites
Ian 2,417 #7 Posted August 29, 2014 A very nice machine Iain, I'd love a "D" in my herd at some point. Share this post Link to post Share on other sites
slf-uk 914 #8 Posted August 29, 2014 Diggerjames, Do you have any attachments with your D200? Both of mine have even have the PTO's missing from the front of the engine. My D200 does have a PTO shaft running front to back and 3pt linkage. Iain Share this post Link to post Share on other sites
Chris 642 #9 Posted August 29, 2014 I had a D200 Iain That had 3point linkage & 5ft mower on the rear Like a muppet I sold it to a mate who has run it into the ground & now awaits restoration The PTO clutch on it has blown so needs replacing Share this post Link to post Share on other sites
diggerjames 543 #10 Posted August 29, 2014 Hi mate no I haven't any attachments at all for it I ended up making my own 3 point linkage . I have a thread on red square doing a full nut and bolt restoration ! Good luck with yours Share this post Link to post Share on other sites
pmackellow 2,728 #11 Posted August 29, 2014 I had a D200 Iain That had 3point linkage & 5ft mower on the rear Like a muppet I sold it to a mate who has run it into the ground & now awaits restoration The PTO clutch on it has blown so needs replacing No chance of buying it back then Chris ?? Share this post Link to post Share on other sites
slf-uk 914 #12 Posted September 1, 2014 I don't suppose anyone has a starter motor they want to sell? The magnets have broken up on the D-160 starter. I have glues the bits back together and it works most of the time, however a replacement would be great. Iain Share this post Link to post Share on other sites
Chris 642 #13 Posted September 1, 2014 No chance of buying it back then Chris ?? Err no I dont think so. It will be done, but when?? Share this post Link to post Share on other sites
pmackellow 2,728 #14 Posted September 1, 2014 Err no I dont think so. It will be done, but when?? Not thought about asking him then?? Share this post Link to post Share on other sites
Ian 2,417 #15 Posted September 2, 2014 I don't suppose anyone has a starter motor they want to sell? The magnets have broken up on the D-160 starter. I have glues the bits back together and it works most of the time, however a replacement would be great. Iain Hi Iain, if the 16hp K series starter is the same as other smaller K series starters then I think I may have a spare starter.. I will have a look when I'm feeling well enough to head out to the shack. Share this post Link to post Share on other sites
slf-uk 914 #16 Posted September 2, 2014 Ian, I believe it is the same and the key bit is getting a starter with the side facing fixing bracket. Thanks Iain Share this post Link to post Share on other sites
Ian 2,417 #17 Posted September 3, 2014 How's this Iain. It came from my first Wh a 74 Raider 10.. I did the jump lead test today and it spins up fine. Share this post Link to post Share on other sites
slf-uk 914 #18 Posted September 4, 2014 Ian, This looks almost perfect. I can't remember mine having a slight overhang with the bracket on the drive end. I will check tonight and get back to you. Thanks Iain Share this post Link to post Share on other sites
slf-uk 914 #19 Posted September 22, 2014 With a big thanks to Ian the D-160 now is fitted with this It works great and now I just need someone to paint the rest of the tractor to match. I quickly fitted a tow hitch to it over the weekend and was using it to pull a trailer around. I have no idea if it was fun to drive because my 7 year old lad decided he would do all the driving. It is a very easy machine for him to drive because he can get by without using the peddle. Iain Share this post Link to post Share on other sites
Ian 2,417 #20 Posted September 24, 2014 Hi Iain Glad the started fitted and works ok Now take control and have a good drive yourself Share this post Link to post Share on other sites
slf-uk 914 #21 Posted September 24, 2014 Ian, thanks again for the starter however I am less sure about the advice about taking control. It would be easier throwing favourite toys away than extracting a tractor from a seven year old. He has already worked out which of my tractors he is going to have when he leaves home. Iain Share this post Link to post Share on other sites
slf-uk 914 #22 Posted December 30, 2016 Today I decided to do some work on the D160. It has been in storage for nearly two years and if I remember correctly the last time it was used was when Tom used it and I believe it kept cutting out. My D160 came out of the factory as poverty specification and it was supplied without a tow hitch or lights and did not have 3pt, PTO shaft or wheel brakes. With the help of friends in the US plus some parts from Harry (via Chris) I have collected a few bits to put on it. It now has lights and a tow hitch and I have most of the parts to put a 3pt on it. Before I started I kicked a few things out of the workshop to give me plenty of space, they are a big machine. I then pulled the complete fuel system off and cleaned out the horrible smelling fuel. The carb got stripped down and went through the Ultrasonic cleaner. With the fuel tank removed and with no 3pt or wheel brakes you have lots of space at the back. It is not uncommon for the panels on these to rust under the fuel tank and mine even has a hole in the panel I hope to have it running tomorrow and then I can focus on some of the repairs I have planned. Iain 2 Triumph66 and Alan reacted to this Share this post Link to post Share on other sites
Triumph66 1,256 #23 Posted December 30, 2016 Iain, that's a damn fine looking machine that. It's interesting to see two D series WH on MOM at the same time. Just out of interest, how good is your ultrasonic cleaner on the carbs? Also how quick is the turnaround? Keep meaning to invest in one myself 1 slf-uk reacted to this Share this post Link to post Share on other sites
harryt 281 #24 Posted December 30, 2016 Glad to see you are recommissioning it. Let me know if you need any more parts as I have doubles of a lot of the important parts, almost another complete hydraulic system! Will look forward to se it up and running again 1 slf-uk reacted to this Share this post Link to post Share on other sites
slf-uk 914 #25 Posted December 30, 2016 18 minutes ago, Triumph66 said: Iain, that's a damn fine looking machine that. It's interesting to see two D series WH on MOM at the same time. Just out of interest, how good is your ultrasonic cleaner on the carbs? Also how quick is the turnaround? Keep meaning to invest in one myself The Ultrasonic cleaner is fantastic tool especially on carbs, the hard bit is finding the right cleaning fluid to use. I have used caustic soda which is the right price but a bit too harsh for alloy parts. I am now testing a fluid specifically designed for carbs and it appears to work well. Earlier in the week when I cleaned the 1962 RAM carb I also put in the glass bowl from the tank tap/filter and it went from brown to looking like new. When I clean the 1961 RAM carb I will take some before and after pictures 12 minutes ago, harryt said: Glad to see you are recommissioning it. Let me know if you need any more parts as I have doubles of a lot of the important parts, almost another complete hydraulic system! Will look forward to se it up and running again Thanks Harry, I am planning to make the remaining parts I need for the 3pt but I know I am missing some bits from both of my D-series, just need to remember which bits. Iain 2 harryt and Triumph66 reacted to this Share this post Link to post Share on other sites
