Darmic1 447 #26 Posted September 24, 2015 Also sorted the air shroud, stripped all the old paint using a heavy duty paint stripper, then a wire wheel. A couple of coats of etch, then some colour........ The "rat" look or not??? NOT! 4 nigel, Stormin, S1g and 1 other reacted to this Share this post Link to post Share on other sites
S1g 579 #27 Posted September 25, 2015 Hi Darren,your parts are going in the post today-I just hadn't had time to strip them till this morning sorry. Make sure you wash the filter when it arrives in petrol or similar as it may be a bit dirty. I know titch does the new I'd plates for the engine. It's starting to look really good, I usually paint mine in John dere green as I bought a very large tin of it way back. Share this post Link to post Share on other sites
Darmic1 447 #28 Posted September 25, 2015 Cheers Gareth! This green is what was beneath the brushed on dark green. No progress today after this mornings excitement. Im back to work tomorrow, so wont be much progress for the next week! Share this post Link to post Share on other sites
Darmic1 447 #29 Posted September 26, 2015 Had the afternoon in the garage today, carb cleaned and rebuilt. The bits arrived from Gareth arrived too, Cheers G! Also got the engine timed, flywheel tightened etc....... Guess what.............. It runs too!!!! Wanna see? https://youtu.be/PeetRoIOQmI Share this post Link to post Share on other sites
Darmic1 447 #30 Posted September 26, 2015 Refitted the cowling, then the carb........ Washed the fuel tank out. will remove all the old paint tomorrow afternoon........ 5 Stormin, S1g, Ian and 2 others reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #31 Posted September 27, 2015 Beautiful job. Share this post Link to post Share on other sites
Darmic1 447 #32 Posted September 27, 2015 Cheers! Get the tank done and then make a start on the rest of the machine. Share this post Link to post Share on other sites
the showman 4,074 #33 Posted September 27, 2015 Top job, looks really nice Share this post Link to post Share on other sites
Triumph66 1,256 #34 Posted September 27, 2015 Another great job. Inspiration for me to make a start on one of my projects Share this post Link to post Share on other sites
Darmic1 447 #35 Posted September 27, 2015 Thanks! I really did think the engine was beyond saving when opened up. However Gareth persuaded me to give it a go..... Its suprising how bad these little engines can be and yet still be bought back from the brink. 'They sure dont make 'em like they used too!' Just hope the rest of the machine can be rescued! Share this post Link to post Share on other sites
phil murrell 41 #36 Posted September 29, 2015 Here is a picture or two of mine still in its work clothes Share this post Link to post Share on other sites
phil murrell 41 #37 Posted September 29, 2015 2 S1g and Triumph66 reacted to this Share this post Link to post Share on other sites
Ian 2,417 #38 Posted September 30, 2015 That's a fantastic job with the engine, I can't wait to see the finished machine Share this post Link to post Share on other sites
the showman 4,074 #39 Posted September 30, 2015 You've got you phone upside down Phil Share this post Link to post Share on other sites
Darmic1 447 #40 Posted September 30, 2015 Hi Phil, Could you get a close up of the handlebars please? As I say, mine are missing and I'm gonna make some new ones......... Ordered 3m of 1" diameter tubing today, just need to find a way of bending it! Thanks Ian, Am going to try to get it done in time to bring to Isfield......... Have 18 days and counting! Share this post Link to post Share on other sites
Darmic1 447 #41 Posted September 30, 2015 Top job, looks really nice Thanks Mr Showman! Share this post Link to post Share on other sites
Darmic1 447 #42 Posted October 1, 2015 Not had much time this week. But have managed to move things along a bit. The fuel tank has been stripped, repaired and primed. The gearbox is now stripped down, cleaned, de-burred the gears and the outer case is now in primer ready for its top coat. The rest of metal work is at the blasters. Have even managed to order the steel tube and a decent tube bender to reproduce the 'missing' handle bars, couldn't believe what a local company were asking just to supply and bend a bit of tubing! 2 S1g and pmackellow reacted to this Share this post Link to post Share on other sites
Charlie Smith 192 #43 Posted October 3, 2015 What a beautiful job you've made, well done! Share this post Link to post Share on other sites
Darmic1 447 #44 Posted October 21, 2015 The Insomnia is back! So I thought i'd show you what I have done with the 1st of my days off. I haven't been happy with the flat colour supplied by the paint shop, so took some bits from the 2nd machine along and trawled through their colour chips until we found what we think is the perfect colour match to the original metallic finish. Its odd how when these machines were made they were able to mix a metallic paint which had a gloss finish to it, yet today it has to be a 2 stage, base colour and clear coat process! The bits were given several light coats of the base and left for around 2 hours to dry. I then activated the 2K clear and sprayed light coats over the base colour. . 2 pmackellow and Ian reacted to this Share this post Link to post Share on other sites
Darmic1 447 #45 Posted October 21, 2015 I then stripped the engine back to a point where I could respray it to the correct colour. Before painting and to ensure a good adhesion I lightly 'scotch bright' the surface and then began the process again. Here's the engine now in the correct colour. Fuel tank was next.......I do like the finish with these ProXL products! Refitted the cowling once dry and the various bits removed for painting back on the Villiers. 9 S1g, the showman, nigel and 6 others reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #46 Posted October 21, 2015 That's very nice. Share this post Link to post Share on other sites
the showman 4,074 #47 Posted October 21, 2015 Top job Darren, looks better than factory finish Share this post Link to post Share on other sites
Ian 2,417 #48 Posted October 21, 2015 Me likes the metalic paint Share this post Link to post Share on other sites
pmackellow 2,738 #49 Posted October 21, 2015 Very posh mate, I haven't forgotten your literature will have a look in a minute... Share this post Link to post Share on other sites
Darmic1 447 #50 Posted October 21, 2015 Cheers guys, and thanks Paul! Paul? Do you happen to have one of those locking clutch levers that we spoke about at Isfield? One that you would be willing to part with??? Share this post Link to post Share on other sites
