the showman
Clinton engines
Found 3 Clinton engines under the bench whilst having a tidy up, they all spin over with plenty of compression, 2 have reduction gearboxs.
i bought them when i was restoring a Trojon tractor but didn't need then.
Might be handy for spares to someone, what they worth to ya £50 for the lot
Chris, might be interested in these possibly for my Bolens Lawn Keeper if compatible.... Hopefully will find out soon.
Can't remember if it was a Clinton or a Lauson engine in there originally!?!
I would have thought they were fitted with a verticle crankshaft engine Andrew ?
You are right Chris; thanks anyway.
That is is what happens when you fire off a post without looking at the photos closely when you are multitasking with getting ready to go on holiday, sort out paperwork, walk the dog etc. Oh well back to the drawing board.
  On 1/30/2018 at 8:28 AM, the showman said:
Any good parts here for you Ewan, might be the same ?
The B1290/1260 engine differs from your red A2160 engine, as it doesn't even have a bearing plate. Ewan needs bearing plate number 12054. Your yellow D790 engine has a bearing plate, but the part number is 12016-A and will not work.
Thanks Alain for checking those numbers for me, however I believe Chris also has an engine which is the same model as mine.
Do you still have the B1260 engine Chris? Thanks
