Stormin 4,458 #1 Posted October 27, 2016 I've been working on a neighbours Lawnflite ride on. I sold them it about 6-7 years ago, in good running order, when I got my Wheel Horse C-125. Two years ago it wanted a new battery and was traveling at a snails pace. Since then it had been left outside with a cover thrown over it. On examination of the drive pulleys etc, I found, though not seized, everything rather stiff in operation. This had caused the drive belt to the gearbox to come off the tension pulley. No wonder it was moving at a snails pace. Stripped it all down and gave it a good clean up. Now working as it should. Next I turned my attention to the engine. 8hp B&S. Battery on and the engine spun like a good 'un. Checked the oil and a good job I did. Nothing on the dipstick. I drained about two cup fulls of very black liquid out and filled with fresh oil. Petrol in and lets see if it will run. After a bit of cranking to get fuel through it fired up and ran fine. Back on the ground and try the clutch and gears. All working ok and then, the throttle cable snapped. I've been told they are now obsolete, so now the hunt is on. 4 Triumph66, 4x4forks, Alan and 1 other reacted to this Share this post Link to post Share on other sites
hpearce 40 #2 Posted October 27, 2016 Jon Cruse at the Mower Centre in Hailsham can make one if you send him the original, Tel 01323 842447 during working hours. 1 Triumph66 reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #3 Posted October 27, 2016 I rooted out some old Wheel Horse cables. The idea was to use an inner in the original outer sheath. Unfortunately the WH inners are a few thou bigger then the Lawnflite one. Share this post Link to post Share on other sites
the showman 4,074 #4 Posted October 27, 2016 Give me some details, length and whats on the ends ect and I'll have a look through my stock Share this post Link to post Share on other sites
Stormin 4,458 #5 Posted October 27, 2016 Thanks Chris, but I don't think it's something you can send by post. Going to try and catch a chap next week, who services/breaks ride ones etc. I'll send a photo and details anyway tomorrow. 2 the showman and HeadExam reacted to this Share this post Link to post Share on other sites
Triumph66 1,256 #6 Posted October 27, 2016 Interesting rider. It's a shame that the new owner is not looking after it but at least it been serviced by you Norm. 2 the showman and HeadExam reacted to this Share this post Link to post Share on other sites
Anglo Traction 1,016 #7 Posted October 27, 2016 6 hours ago, Stormin said: .........Back on the ground and try the clutch and gears. All working ok and then, the throttle cable snapped. It clearly remembers you Norm!. It broke it's cable so it didn't have to go back. That Oil you got out of it was probably what's left of the Oil you put in several years ago. 1 HeadExam reacted to this Share this post Link to post Share on other sites
Wristpin 400 #8 Posted October 27, 2016 (edited) Throttle cable. You just need a bit of piano wire . Put a "dog leg" in the control end of it , split the control box and hook it into the lever and poke it down the outer with a couple of inches protruding , clamp the outer onto the BS throttle / governor plate and eye up the appropriate length before making the final dog leg to hook into the throttle lever. A lot easier than it sounds! The original part number was 746-0503 P.S. BARRUS are showing available stock!! £8.53 + vat Edited October 27, 2016 by Wristpin Aditional info re availability 1 nigel reacted to this Share this post Link to post Share on other sites
HeadExam 1,783 #9 Posted October 28, 2016 It looks like a 18 hp v twin might fit, lol Share this post Link to post Share on other sites
C-101plowerpower 548 #10 Posted October 28, 2016 3 hours ago, HeadExam said: It looks like a 18 hp v twin might fit, lol i think that would make it a lawnflight 1 HeadExam reacted to this Share this post Link to post Share on other sites
Wristpin 400 #11 Posted October 28, 2016 Or fright! 1 HeadExam reacted to this Share this post Link to post Share on other sites
HeadExam 1,783 #12 Posted October 28, 2016 might need a spoiler, front air dam, and solid tyres though. Nigel could do it Share this post Link to post Share on other sites
Stormin 4,458 #13 Posted October 28, 2016 Well it's up and running now. Throttle cable sourced of a Mountfield walk behind mower. Needed shortening and the ferrul into the control lever case modifying a bit. After a run round, ran sweet and no smoke. Job done! 1 Triumph66 reacted to this Share this post Link to post Share on other sites
the showman 4,074 #14 Posted October 28, 2016 That's good news Norm, I forgot to look at mine spose it don't matter anyway now. Share this post Link to post Share on other sites
