S1g 579 #1 Posted February 19, 2017 This is a project that ive been doing on and off for a few years. Anyway, over the last few days I have dug it back out due mainly to the fact that I haven't picked up a spray gun in 6 months and wanted to have a bit of a practice session before I sprayed my Sachs diesel Gem. I was also unsure how my new batch of primmer would react to Vapormatic Howard Orange. Well im pleased to report that it worked a treat. The history behind these machines is that by 1960 Howard had been increasingly frustrated with losing out sales to what they termed "Scratchers". Their solution was to start import the Hako Combinette, as a direct competitor to machines like the Wolesy Merrytiller. The problem was by the time Howard had put their mark up on the price, these rotadiggers (note how they didn't call them Rotavator's)were just too expensive to be competitive. After about a year to 18mths the project was dropped,making suvivours quite hard to come by. This example turned up on good ol' ebay in 2013. I placed a low bid on it and won. 3 Darmic1, Stormin and pmackellow reacted to this Share this post Link to post Share on other sites
S1g 579 #2 Posted February 19, 2017 The engine on these machines are a JLO two stroke. As ive said before on here this engine design was purchased by the construction company Wacker, so a good friend of mine, who is a retired Wacker service engineer said he would rebuild it for me. I took this plus another old short motor I had lying around up to him. Even though the seller claimed it was running when put away in the shed (where have we heard that before?) it still needed a crankcase half, piston rings, seals, bearings and a set of points, all courtesy of Wackers scrap bin many years ago when they decided to make the engine obsolete! It has now had a full clean up. Ive also dug through my sheds and found an as new cylinder head so will be fitting this over the next few days. 3 Stormin, pmackellow and Darmic1 reacted to this Share this post Link to post Share on other sites
S1g 579 #3 Posted February 19, 2017 The basic machine with the engine removed looked pretty grotty, but after a hot wash this came up surprisingly well. Next several applications of paint stripper followed. Then I applied a few coats of a new primmer (as stated above I wanted to see how it worked with the Howard Orange.) 3 pmackellow, Stormin and Darmic1 reacted to this Share this post Link to post Share on other sites
S1g 579 #4 Posted February 19, 2017 This morning after checking the forecast for the coming week I went to my worked and sprayed the top coat. This will be left to dry for a few days. In the meantime I will start painting all the black bits. I purposely am not going to go over the top, as I would like to put this machine to work, once its finished. 5 Darmic1, Alan, Stormin and 2 others reacted to this Share this post Link to post Share on other sites
S1g 579 #6 Posted February 19, 2017 24 minutes ago, Stormin said: That JLO engine rings a bell. Is there something else on here somewhere with one? My Wacker plate and trench rammer use the same engine. 2 Stormin and pmackellow reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #8 Posted February 19, 2017 Yep! Knew I'd seen one before. Not completely senile yet. 2 pmackellow and S1g reacted to this Share this post Link to post Share on other sites
S1g 579 #17 Posted February 20, 2017 Engine has now been trial fitted and the exhaust has had a coat of VHT silver. 4 Cub Cadet, Stormin, pmackellow and 1 other reacted to this Share this post Link to post Share on other sites
S1g 579 #18 Posted February 28, 2017 Managed to make a bit more progress today, sorry for the poor quality photos, as I only had my phone with me. 5 Stormin, Cub Cadet, Alan and 2 others reacted to this Share this post Link to post Share on other sites
S1g 579 #24 Posted March 1, 2017 heres a photo. 4 Cub Cadet, pmackellow, Stormin and 1 other reacted to this Share this post Link to post Share on other sites
