JUST O&R 237 #151 Posted December 14, 2019 (edited) looks great when your ready to get it out of your way let me know Edited December 15, 2019 by JUST O&R Share this post Link to post Share on other sites
CNew 408 #152 Posted December 28, 2019 On 10/13/2019 at 6:05 PM, DCM said: Okay, I honestly didn`t expect all these replies. DCM, Did you get the diaphragm and needle assembly you were needing? I lost track of this thread while I was moving. Hopefully you have everything you need to get your Aquabug up and running. Looking forward to hearing how the project is going. Share this post Link to post Share on other sites
pmackellow 2,738 #153 Posted January 6, 2021 Finally got around to cleaning up the Aquabug cover that my mate got mended for me Its now in the display next to the machine, I still think it looks better without the cover so am leaving it off for now... 2 JUST O&R and CNew reacted to this Share this post Link to post Share on other sites
factory 487 #154 Posted January 7, 2021 Looks very good Paul, what happened to the damaged tank? I now have some more information for the Aquabug's to scan in at some point. David Share this post Link to post Share on other sites
pmackellow 2,738 #155 Posted January 7, 2021 1 hour ago, factory said: Looks very good Paul, what happened to the damaged tank? I now have some more information for the Aquabug's to scan in at some point. David Still got that in a box upstairs David Oh good, any Aquabug information always useful thanks ! Paul Share this post Link to post Share on other sites
CNew 408 #156 Posted January 8, 2021 That turned out great! 1 pmackellow reacted to this Share this post Link to post Share on other sites
DCM 2 #157 Posted July 24, 2023 I did get this Aquabug running recently. I bought the gasket and diaphragm on ebay. I do have question on if anyone knows where i can purchase a throttle handle. The aquabug runs and sounds good but has a small leak coming from part of the carburetor, see in picture, i don't know what its called. any advice would be helpful. Also the starter pulley return sounds like it needs lubrication its slow to return and makes a lot of noise any advice would help. I`m sorry I haven`t responded because I just worked on it a couple of weeks ago. If it wasn`t for all your advice and help, I never would have got this running. Share this post Link to post Share on other sites
Wallfish 716 #158 Posted July 31, 2023 Difficult to find throttle and cable for that. You're going to have to get creative like using a mini bike throttle kit. That leak is at the governor spring. Fuel shouldn't be passing the little ball bearing check valve in the carb unless the engine is running. When running it shouldn't be leaking because all the fuel is being sucked into the engine to run. You might have to pull the carb apart and clean the bearing and seat real well because it should seal. Or replace that bearing too Share this post Link to post Share on other sites
DCM 2 #159 Posted July 31, 2023 Okay, I will try cleaning first. Are the parts available if needed? I`m assuming the ball bearing check valve is one piece with no actual ball bearing. Could it also actually be its getting too much fuel and the needle valve needs to be adjusted? Also the recoil pull cord is sluggish or slow and sounds like it needs lubrication or something. Throttle handle is broken but functional. It has a clamp around it, but want to be prepared in case it breaks. Thank you for responding its been four years since I first and last posted, i never really had the time to work on it. If you click on my DCM link it should take you to my post of the motor running. i couldn`t fit in this post. Share this post Link to post Share on other sites
Sharri Dandy 5 #160 Posted August 2, 2024 Just got my hands on a little Perry Aquabug. Reasonable condition but the fuel tank and cover are missing. Bit of a long shot but does anyone have any spares? Share this post Link to post Share on other sites
Wallfish 716 #161 Posted August 2, 2024 2 hours ago, Sharri Dandy said: Just got my hands on a little Perry Aquabug. Reasonable condition but the fuel tank and cover are missing. Bit of a long shot but does anyone have any spares? Personally I think they look better without the plastic cover and with a regular O&R gas tank, so maybe go with that until you can locate the proper tank and cover. Share this post Link to post Share on other sites
CNew 408 #162 Posted August 3, 2024 I’m with Wallfish, I also think they look better without the cover and with a standard gas tank. Share this post Link to post Share on other sites
Sharri Dandy 5 #163 Posted August 3, 2024 Nice idea. I can see that working. I'll have a rummage later and see what I have. Sure I have one. I might be back on looking for a tank. Thank you Share this post Link to post Share on other sites
CNew 408 #164 Posted August 3, 2024 Tanks don’t come up often but there is one available now… https://www.ebay.com/itm/256546196755?itmmeta=01J4C4WZEQ0KGXH23T5XAP0114&hash=item3bbb584d13:g:gkMAAOSwZZFmcD0f&itmprp=enc%3AAQAJAAAA4BHjIXw2BblhGVDWj6VzdEEJFMk3Qp2YEM%2FRVenrZRQ1LwU3CXg0LellU%2FTYORCQD5YtFx9%2F3WGHIjtNHrjOAiFiEM7Vw2rrAcwhac8Myf7VfL%2FSontjS%2BhU%2BaTyh%2FwoRZ6Ie5usQO6A4EE7qIizefirMOzXYB99s3tSZ3TfNCTZd%2FXAPEwKoUu70mpRbp5vjyVVCYoNDyXMZDczMe1F3PEiIn79%2BWiTK9gfpqYB1vzewF4%2BfjcHwIYc6m4oeDfnq2Vz%2Fe9O%2BcgbFhAcgrzJB2a88HwMt24FLeyBmZPyj5Og|tkp%3ABk9SR7r384SjZA Share this post Link to post Share on other sites
Wallfish 716 #165 Posted August 5, 2024 On 8/3/2024 at 8:55 AM, CNew said: Tanks don’t come up often but there is one available now… https://www.ebay.com/itm/256546196755?itmmeta=01J4C4WZEQ0KGXH23T5XAP0114&hash=item3bbb584d13:g:gkMAAOSwZZFmcD0f&itmprp=enc%3AAQAJAAAA4BHjIXw2BblhGVDWj6VzdEEJFMk3Qp2YEM%2FRVenrZRQ1LwU3CXg0LellU%2FTYORCQD5YtFx9%2F3WGHIjtNHrjOAiFiEM7Vw2rrAcwhac8Myf7VfL%2FSontjS%2BhU%2BaTyh%2FwoRZ6Ie5usQO6A4EE7qIizefirMOzXYB99s3tSZ3TfNCTZd%2FXAPEwKoUu70mpRbp5vjyVVCYoNDyXMZDczMe1F3PEiIn79%2BWiTK9gfpqYB1vzewF4%2BfjcHwIYc6m4oeDfnq2Vz%2Fe9O%2BcgbFhAcgrzJB2a88HwMt24FLeyBmZPyj5Og|tkp%3ABk9SR7r384SjZA OUCH Share this post Link to post Share on other sites
Sharri Dandy 5 #166 Posted August 5, 2024 With postage and tax that's a good bit more than I paid for the Aquabug delivered. I shouldn't keep putting a price on these things and think of the end result. May just hold out for something a wee bargain as I am in no rush. Share this post Link to post Share on other sites
Wallfish 716 #167 Posted August 6, 2024 The original Aquabug gas tanks are fairly hard to come by. The cap has a little fold-able vent and when it's left closed the tank is sealed tight, then change in temperature will cause pressure which expands and contracts the air inside, and that cracks the plastic seems. That's exactly what happened to my first one so I learned to leave that vent open. Pretty sure many of them met their demise the same way when being stored. Share this post Link to post Share on other sites
Sharri Dandy 5 #168 Posted August 6, 2024 Well I'm in the market for one if one ever becomes available. Even if I'm waiting a few years Share this post Link to post Share on other sites
Mike in NC 37 #169 Posted August 20, 2024 Has anyone seen an electric conversion for the Aquabug? Share this post Link to post Share on other sites
Wallfish 716 #170 Posted August 22, 2024 On 8/19/2024 at 10:03 PM, Mike in NC said: Has anyone seen an electric conversion for the Aquabug? I do remember someone posted one that could switch back and forth from gas to electric but I cannot seem to find it now. It could've been way back on the old forum before we switched to here. Lots of that info was lost 1 Mike in NC reacted to this Share this post Link to post Share on other sites
