Stormin 4,458 #1 Posted February 1, 2014 I built this out of what I had lying around, in anticipation of snow last winter. I'm still waiting. First a frame was made using some 1-5/8 bore pipe and box section. Then the front end put together The blade was made at the local smithy. No rollers big enough, so it was curved in stages on a folder. I made my own tach-o-matic for the rear. Then this dodgy character nicked it. 3 Cub Cadet, Westie1 and nylyon reacted to this Share this post Link to post Share on other sites
C-101plowerpower 548 #2 Posted February 1, 2014 looks real good norm did you push anything with it yet? Koen Share this post Link to post Share on other sites
meadowfield 1,901 #3 Posted February 1, 2014 Great build pics Norm! Share this post Link to post Share on other sites
Stormin 4,458 #4 Posted February 1, 2014 looks real good norm did you push anything with it yet? Koen Fitted a rubber strip to the blade and cleaned the lane by us. Share this post Link to post Share on other sites
neil 524 #5 Posted February 1, 2014 Good bit of fabricating Norm , looks nice n strong Share this post Link to post Share on other sites
nigel 1,881 #6 Posted February 2, 2014 very nice norm Share this post Link to post Share on other sites
Stormin 4,458 #7 Posted October 27, 2019 One thing the plough/dozer blade is missing, is the handle and linkage to pivot the blade, left, right and centre. So the handle I made has been gathering dust on a shelf. Yesterday I fitted it then had a scrat about for parts for the linkage. The results are in the following photos. That section works. Now to find or make a lever to operate the fulcrum, to pull the chain, to operate the locating pin. 2 Cub Cadet and Triumph66 reacted to this Share this post Link to post Share on other sites
the showman 4,074 #8 Posted October 27, 2019 Use a brake lever off a push bike and some 1/4 rod Share this post Link to post Share on other sites
Stormin 4,458 #9 Posted October 27, 2019 10 minutes ago, the showman said: Use a brake lever off a push bike and some 1/4 rod That's what I'm thinking. Some old bikes up at the farm. Share this post Link to post Share on other sites
expeatfarmer 591 #10 Posted October 28, 2019 Looks good Norman, you and I must be thinking we are going to have a bad winter I have been trying to find a snow blower to fit my Turf Trak. Share this post Link to post Share on other sites
Stormin 4,458 #11 Posted October 28, 2019 I doubt we'll get much down here on the plain, Jonathan. I think you get our share up there, on the edge of the fells. Share this post Link to post Share on other sites
Stormin 4,458 #12 Posted November 4, 2019 Got a couple of bicycle brake levers from a scrap farm bike. Bit of a mod to were it fitted to the handle bar and connected it up. After drilling a hole through a 6mm set screw to thread the bicycle cable through. Hit a snag here. The lever not being straight fouled the handle when pulled right back. So I shortened the lever. Finally I did away with the R clip that held the chain to the location pin. Threaded the hole 6mm and secured the chain. Might throw some paint at it sometime. Also see if I can find a straight steel lever to fit. Maybe not pretty but it works and it cost me nowt. 3 the showman, Cub Cadet and Alan reacted to this Share this post Link to post Share on other sites
