4x4forks 258 #1 Posted November 11, 2018 The Kubota B6100 Story go's on. The three cylinder D650 engine has had a few issues in this tractor but once it gets running it was fine and had loads of power. Howevery starting has been an issue loads of smoke and loads of heat plugs. I overhauled the diesel injectors and this had no improvement. I relented and purchased a diesel compression tester. At very best i was getting around 220psi on the best cylinder. The book states it should be up around 400 to 460 psi. OPPS !! After researching the costs I could purchase the parts from ether Kubota or a chines copy company. I was advised to go genuine. I turns out that I have a very early engine 000236. As the bits are on order the clean up begins. I am going to have new liners pressed in and all new bearings ,seals and gaskets. Will update as the build go's on 3 HeadExam, WestwoodGazelle and Stormin reacted to this Share this post Link to post Share on other sites
Chris 642 #2 Posted November 11, 2018 I was going to say low on compression 1 4x4forks reacted to this Share this post Link to post Share on other sites
4x4forks 258 #3 Posted November 12, 2018 Block is back with new liners . Apparently it took all a 10 ton press could do with a hot block and frozen liners. once in then machined to correct size for standard rings. Quick coat of fresh paint and now start to replace all bearings. 4 Cub Cadet, Stormin, Alan and 1 other reacted to this Share this post Link to post Share on other sites
4x4forks 258 #4 Posted November 13, 2018 crank in with new main bearings . Pistons and rods in all new bearings . flywheel fitted. I will hang it back on the engine now as it is still lift able at this stage 2 Stormin and Anglo Traction reacted to this Share this post Link to post Share on other sites
Anglo Traction 1,023 #5 Posted November 13, 2018 Fine example of a 'Proper Job' 1 4x4forks reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #6 Posted November 13, 2018 Wot 'e said. Share this post Link to post Share on other sites
4x4forks 258 #7 Posted November 13, 2018 Shes a runner !!!!!! Number one is smokey .I think possible injector problem. I will swop over cylinders and see if smoke moves. 1 Stormin reacted to this Share this post Link to post Share on other sites
4x4forks 258 #8 Posted November 13, 2018 After tea I opted to drop the rad on and give it another run . With a few more revs and heat in the engine she ran up clean and smooth. I will see what its like cold in the morning and refit the front axle. 1 Stormin reacted to this Share this post Link to post Share on other sites
4x4forks 258 #9 Posted November 14, 2018 Well she drives again. It Appears I have a poor injector. Number one is smoke on start up but clears after a short time . Going to get them properly checked and overhauled but it will run and starts loads better than it did. 2 Anglo Traction and Stormin reacted to this Share this post Link to post Share on other sites
Anglo Traction 1,023 #10 Posted November 15, 2018 You made short work of that job. Impressive . I do like that Kubota Blue. Enjoy the seat time 1 4x4forks reacted to this Share this post Link to post Share on other sites
4x4forks 258 #11 Posted November 15, 2018 After a bit of running It still smokes badly on cylinder one. on start up also dosn,t sound as it is running on all three until it starts to warm up then all is fine . I have removed the injectors and had them tested today . I have replaced all three injector needles with items new from ebay. On testing all the spray pattens on the injectors are appalling . so New genuine needles on order and set up. Hope this will make things a bit less smokey. Share this post Link to post Share on other sites
4x4forks 258 #12 Posted November 16, 2018 WHAT A DIFFERENCE!!!!!! Picked up my injectors after being overhauled with genuine Nozzles. less than 24hrs from drop off to collection Fantastic service. Fitted , bleed and fired up first time . No smoke and runs like a new engine . It runs smoother and cooler now . I think washing out the block helped. Having a temp gauge now gives faith in what is happening. I will in time fit an oil pressure gauge. Now need a few fields to plough to bed it all in. 1 Stormin reacted to this Share this post Link to post Share on other sites
4x4forks 258 #13 Posted November 18, 2018 Note to self Do a job properly! Found a damp patch under the tractor this morning. It could only be coming from one place. The core plug behind the flywheel. Up Side is I have got this splitting the tractor in half down to a quick job now. Share this post Link to post Share on other sites
Stormin 4,458 #14 Posted November 18, 2018 That does look a tad rotten. 1 4x4forks reacted to this Share this post Link to post Share on other sites
