meadowfield 1,900 #226 Posted December 24, 2014 I think this is the last update for Xmas, brackets and a pin made. Rear lift now finished but for pipes and paint 2 Cub Cadet and Ian reacted to this Share this post Link to post Share on other sites
meadowfield 1,900 #231 Posted December 27, 2014 that was the original plan Doug, but there's just not enough room - I did the calculations. At 700psi (powersteering pump) it will lift 0.17 tons, and push down 0.24 tons.. With a decent geared pump (3000 psi) it will lift 0.74 tons and push down just over a ton. I think 700 psi is a good start point, that would lift me at the end of the lift arms I've got 4 10l -3/8 bspp fittings already, but they are the same at both end have you got some with metric thread on the other end? used some more of those brackets today to make part of the front three point hitch, plus turned some 19mm bushes down. cheers 2 diggerjames and Cub Cadet reacted to this Share this post Link to post Share on other sites
diggerjames 543 #236 Posted December 30, 2014 Had a trips to Marks you today for a Natter and a swap if mower decks (Cheers Ian by the way )and I had the privilege of driving bendy in one word wow what a machine I only drove it around the drive but everything feels right the steering is awesome and the driving position is spot on its a work of art whilst I was there I didn't manage to take any photos but I'm sure Mark and Sam did well done mate cheers James Good to see you.... 4 Ian, OldBuzzard, Triumph66 and 1 other reacted to this Share this post Link to post Share on other sites
norlett 32 #237 Posted December 31, 2014 Well worth a visit to see the Bendy in action...Looks good and works good. 2 meadowfield and diggerjames reacted to this Share this post Link to post Share on other sites
meadowfield 1,900 #242 Posted January 16, 2015 cold and snowy outside, so got on inside and made a custom dash decal. The existing dash panel is in pretty good condition, but needs painting and I'd prefer the electric clutch to be something else so here is a new panel. 5 ranger, Ian, Cub Cadet and 2 others reacted to this Share this post Link to post Share on other sites
meadowfield 1,900 #246 Posted January 23, 2015 Latest sticker order arrived today, so the lower dash panel is complete. 4 diggerjames, nigel, the showman and 1 other reacted to this Share this post Link to post Share on other sites
the showman 4,074 #249 Posted January 23, 2015 The mutts nuts Mark 2 nigel and meadowfield reacted to this Share this post Link to post Share on other sites
meadowfield 1,900 #250 Posted January 24, 2015 Thanks guys, finished the upper dash panel too. It's a lot easier than painting and lettering Plus I can change the words... 5 bowtiebutler956, nigel, OldBuzzard and 2 others reacted to this Share this post Link to post Share on other sites
