Alan 1,274 #26 Posted February 9, 2020 Looking good Nigel. 1 nigel reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #27 Posted February 9, 2020 Very nice. 1 nigel reacted to this Share this post Link to post Share on other sites
the showman 4,074 #28 Posted February 9, 2020 Looks good Nigel, you'll have it finished next week 1 nigel reacted to this Share this post Link to post Share on other sites
pmackellow 2,738 #29 Posted February 9, 2020 1 nigel reacted to this Share this post Link to post Share on other sites
nigel 1,881 #30 Posted February 10, 2020 I decided to paint the black bits instead of vinyl because I have always found you get creases when you do large areas I will put the decals on later 5 Ian, the showman, pmackellow and 2 others reacted to this Share this post Link to post Share on other sites
Ian 2,417 #31 Posted February 13, 2020 Having seen this machine yesterday I can confirm that it does look as good as it looks Nice work mate Share this post Link to post Share on other sites
nigel 1,881 #32 Posted February 13, 2020 Bit more done 5 Stormin, the showman, pmackellow and 2 others reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #33 Posted February 13, 2020 Looking good. For a John Deere. 1 nigel reacted to this Share this post Link to post Share on other sites
the showman 4,074 #34 Posted February 13, 2020 So far. So good. 1 nigel reacted to this Share this post Link to post Share on other sites
Charlie231 2 #35 Posted February 15, 2020 Wow! You've done a great job so far Nigel. Looking like a new machine already 1 nigel reacted to this Share this post Link to post Share on other sites
nigel 1,881 #36 Posted February 26, 2020 Engine in 6 harryt, Triumph66, Alan and 3 others reacted to this Share this post Link to post Share on other sites
nigel 1,881 #37 Posted February 27, 2020 Realy pissed of got bonnet on today, and then cracked it 1 2 Cub Cadet, Stormin and pmackellow reacted to this Share this post Link to post Share on other sites
pmackellow 2,738 #38 Posted February 27, 2020 Looks good from here mate, bet you were well annoyed Share this post Link to post Share on other sites
the showman 4,074 #39 Posted February 27, 2020 That’s a bugger mate, how did you manage that ? Share this post Link to post Share on other sites
nigel 1,881 #40 Posted February 27, 2020 4 hours ago, pmackellow said: Looks good from here mate, bet you were well annoyed 3 hours ago, the showman said: That’s a bugger mate, how did you manage that ? Bonnet fits on 2 pegs so you have to spread the bonnet to get it on, and it cracked one of the repairs that I had done 😡 4 Stormin, Alan, Triumph66 and 1 other reacted to this Share this post Link to post Share on other sites
nigel 1,881 #41 Posted March 2, 2020 Just come across the first major cockup can you see it Share this post Link to post Share on other sites
Stormin 4,458 #42 Posted March 2, 2020 Looks to me that, that pedal won't clear the air filter? Share this post Link to post Share on other sites
the showman 4,074 #43 Posted March 2, 2020 Can you grind the weld off the pedal bracket and move the pedal out an inch. ? Share this post Link to post Share on other sites
nigel 1,881 #44 Posted March 2, 2020 22 minutes ago, the showman said: Can you grind the weld off the pedal bracket and move the pedal out an inch. ? No I’ve found out on the Jd 70 it has a bend from the carb to the air filter which would raise it above the pedal and then the filter sticks out at An angle, so I will be cutting a lawn mower handle up tomorrow and will make a couple of flanges up 1 the showman reacted to this Share this post Link to post Share on other sites
nigel 1,881 #45 Posted March 3, 2020 Cock up sorted 6 Stormin, Triumph66, Cub Cadet and 3 others reacted to this Share this post Link to post Share on other sites
the showman 4,074 #46 Posted March 3, 2020 I think you may need to drill a small drain hole as the filter looks like its facing up and might catch water off the bonnet 2 Cub Cadet and Stormin reacted to this Share this post Link to post Share on other sites
nigel 1,881 #47 Posted March 3, 2020 23 minutes ago, the showman said: I think you may need to drill a small drain hole as the filter looks like its facing up and might catch water off the bonnet I won’t be taking it out in the wet chris 😂 suggestion noted, will have a look tomorrow 3 Stormin, the showman and Triumph66 reacted to this Share this post Link to post Share on other sites
nigel 1,881 #48 Posted March 7, 2020 Well it’s off the bench a few more bits to do but it’s getting there 7 Anglo Traction, Alan, Triumph66 and 4 others reacted to this Share this post Link to post Share on other sites
Anglo Traction 1,018 #49 Posted March 7, 2020 Superb job on that Nigel . Even more of an acheivement when it looks like it still has a V70 Techy with a series 1 Lauson carb! and you get it running sweetly. Share this post Link to post Share on other sites
pmackellow 2,738 #50 Posted March 7, 2020 Canine genitalia mate 2 Alan and nigel reacted to this Share this post Link to post Share on other sites
