Not over interested in the engine however very impressed with the dedication to re invent the design and quality of your work.
I manufacture many special parts for the Ransomes MG and also the Triumph TR range of cars.
Well done.
Not aware of the machine but have you looked at https://www.diyspareparts.com/parts/hayter
I am just a happy user for other odd machine parts.
Neil
I agree for initial assembly the ring gaps should not be in line but during running the rings will rotate around so at some points the gaps will align.
Neil
There is a bellows for a different make of scroll saw listed on ebay. I do not know if it is the same.
Jonathan,
Pleased to see you have been out and about. Shrewsbury show always good.
Neil
Norm,
Sorry I do not know the answer but stationaryengines.com list the rings and bearings so can probably tell you.
I also see that agrimanuals.com have copies of the operators handbook available.
Neil
Bet you are very sad to see this one go.
H,
There are more members here in the UK than in the USA (take a look at the member map).
There are a number of people who remanufacture parts and have become specialists in specific machines.
Personally as my hobby I supply the majority of Ransomes MG spares.
Please do not take this as a critisism of your thoughts but the problems of what you suggest are many fold.
CNC machines (Computer Numerically Controlled) are very expensive and take several forms plus specific tooling can seriously add costs.
I have a reliable number of suppliers who do manufacture parts on my behalf when I do not have the facilities but it can take many years before I see any return on investments made.
Establishing precise engineering specifications for parts can take many years of research and may just not have sufficient returns to cover time and costs.
Safety is a paramount concern for some parts and manufacture would probably be avoided by anybody charging for the part.
Many of our parts are very heavy and some owners around the world have to suffer huge carriage costs whch restricts demand.
If your friend has access to specific machines and skills he could off these on the site or VHGMC.
These are only my observations and not trying to put you off trying which I applaud and I wish you good luck and success.
Stay Safe.
Neil
I know very little about the Bristol 20 track but have been asked if I could make replacement rubbers as I manufacture replacements for the Ransomes MG.
Currently I have no idea what they might look like other than they are very different to the MG ones so any help would be very helpful.
If I believe I can make them I will get some old parts from the person asking for them but he does not wish to strip a track if there is no opportunity to replace the rubbers.
Thanks in advance.
Stay Safe
Neil
I have finally taken delivery of new Amal 244 brass floats for the Ransomes tractors.
Contact me if you need one.
Stay Safe.
Neil
I am happy to say I will be getting a delivery of replacement steel flywheels for Ransomes MG2 tractors.
I took the decision to commission a number of these to be manufactured to help with the common breakage issue.
I will not get another batch machined so first come first served.
£205.00 plus carriage.
Contact me on njarrett@btinternet.com
Stay Safe.
Neil
I am investigating getting a batch of metal floats manufactured for the Amal 244 carburettor used on Ransomes MG crawlers.
Indicated costs would be £80.00 so need to see what people think.
Please let me know.
Neil
We need to get some serious commitments to order these before we could consider manufacture due to the set up costs.
If you do think you need a flywheel please do not sit back and wait for them to be available as currently it appears there is not enough demand.
Jonathan,
Happy birthday and to a better year.
Have a good one.
Iain,
Here is a good UK supplier for these.
Springfix Linkages
(Automotion Components Ltd)
Alexia House
Little Mead Industrial Estate
Cranleigh
Surrey GU6 8NE (UK)
Telephone 01483 26 6784
Fax 01483 26 6785
info@springfixlinkages.com
Neil
OK,
Are you convinced you have a good spark under compression not just in clear air?
You can get an indication of this from a spark tell tale in the lead on the installed plug or by using a spare plug touching the installed plug.
Neil
Joe,
Just brainstorming.
Are you totally sure you have the magneto timed correctly
The impulse release should be at TDC. with both valves closed.
Alternatively have you timed the valves to crank correctly?
Neil
Joe,
If the slides are badly worn the air may be entering down from the top rather than being drawn through the inlet. If this is the case there will not be the correct quantity of petrol siphoned through the jets. Try wrapping a plastic bag around the top to eliminate the possible source.
Have you got the air pipe and filter connected with the oil in the air filter bath. If not the air flow at cranking may be to fast and not mixing with the fuel.
You need to ensure the fuel level is high enough in the float bowl. Flood with the tickler.
Neil
Not wishing to be to controversial but my experience shows more capacitor failures with a magneto ignition if used with a resistor plug or a suppressor cap which has the same affect.
Look at http://www.brightsparkmagnetos.com and see the results obtained with a controlled test.
Resistor plugs OK with coil ignition.
Neil
May be worth checking the wheel on the other side as well.
Neil
Joe,
I agree with Jonathan that the gudgeon pin has moved and scored the bore.
You have 2 choices.
1. Replace the barrel and maybe the piston depending on size and condition.
2. Rebore oversize if you can locate a suitable piston.
I have new oversize gudgeon pins and the pads unless you have the later piston that was fitted with circlips.
Neil
Joe,
There is a brand new 60 thou oversize piston on ebay which is a really good price and may resolve the problem.
Nothing to do with me as it is in the Netherlands.
Neil
Jonathan,
The company is Eastwood and is available from Frost www.frost.co.uk
Neil
Nice picture of a frost ! When are you expecting the snow?
OK in that case it must be a Huttenwrk AG Mittelstadt
Neil
I think it is a Staub Lunic ?
Neil
