meadowfield 1,900 #1 Posted February 21, 2015 I've been a big fan of e tanks for a while now, they are great labour saving items and work wonders on all manner of things. Here's my small setup on the bench cooking small pieces for bendy. These were lug nuts with 45w of power running through them, you can't see the gassing - but a reasonable amount of hydrogen was being given off So this is only one half of the set up... I looked into electro plating years ago and just couldn't lay my hands on the correct electrolyte. It was a bit Heath Robinson even by my standards About 6 months ago my brother managed to source a kit and has had some pretty good results tarting up parts on his range rover. So I bought the chemicals and some zinc before Xmas. So now the other half is my plating rig, parts go in rusty or bare metal and come out shiny and fairly rust resistant. The camera doesn't do it justice on some of the pieces. Here's a few bits we've done Which means bendy can actually get 5 bolts per wheel, when I get them all cleaned 1 nigel reacted to this Share this post Link to post Share on other sites
pmackellow 2,728 #2 Posted February 21, 2015 Looking good Mark that setup does a good job !! Share this post Link to post Share on other sites
C-101plowerpower 548 #3 Posted February 21, 2015 looks very pretty, now, where did you get those chemicals? and maybe some instructions? Share this post Link to post Share on other sites
Stormin 4,458 #4 Posted February 21, 2015 Interesting stuff, Mark. When can I bring some bits over? Share this post Link to post Share on other sites
C-101plowerpower 548 #5 Posted February 21, 2015 Interesting stuff, Mark. When can I bring some bits over? bring the wheels of the black horse Share this post Link to post Share on other sites
neil 524 #6 Posted February 21, 2015 Good work Mark, what would be the rough cost to set that lot up ???? Share this post Link to post Share on other sites
meadowfield 1,900 #7 Posted February 21, 2015 Looking good Mark that setup does a good job !! I'm happy with it Share this post Link to post Share on other sites
Tom 215 #8 Posted February 21, 2015 That looks great Mark, nice setup! Would also be interest in more details as to how it all works. Tom Share this post Link to post Share on other sites
meadowfield 1,900 #9 Posted February 21, 2015 looks very pretty, now, where did you get those chemicals? and maybe some instructions? The ammonium chloride, and zinc chloride are part of a kit I managed to buy. The bits separately were more expensive than paying for a packaged kit. The expensive bit that helps is a really good power supply. The hardest bit is the cleaning, everything has to be spotless, the plating then takes 30 mins Interesting stuff, Mark. When can I bring some bits over? If they are small enough and spotless, you are welcome to see the results! Good work Mark, what would be the rough cost to set that lot up ???? About £80, not including the power supply Neil 1 neil reacted to this Share this post Link to post Share on other sites
Ian 2,417 #10 Posted February 24, 2015 Very interesting Mark, I might have to buy a kit when I have some spare funds.. Add a bit of bling to Why Not Share this post Link to post Share on other sites
Wristpin 399 #11 Posted September 20, 2015 I've just up sized my e-tank from a 20 litre storage box to a 205 litre drum. My power supply is a 12 volt battery charger that seems to be running it at around 2.5 amps. Does this seem about right? Have found some instructions and a circuit diagram for a dedicated power supply on the net but I'm better with a spanner than a soldering iron! 1 C-101plowerpower reacted to this Share this post Link to post Share on other sites
Anglo Traction 998 #12 Posted September 21, 2015 From what I have read, learned and tested over the years of using this process, the best Battery Charger set up is to have an older type Charger that has no 'Auto Reduction' or Cut Out. 4 Amps is about ideal, but I've obtained good results with 2.5 amps (or less) and used an Auto Reduction Charger . It just takes longer to do it's job on large pieces/panels. Power/efficiency reduces with build up of corrosion on the Anode Rod(s) and resistance increases ,so you can work with what you have if you clean the Rods regularly and keep the gap between Anode and the Work piece to a reasonably close position. A handy method I use is to have 2 sets of Anode Rods. I use one set then switch them over, but use the process to clean the old Rods, saves a lot of cleaning. Share this post Link to post Share on other sites
Wristpin 399 #13 Posted September 21, 2015 Thanks for the suggestions. At present my anode is a section of steel grid facing the target area but I'm in the process of obtaining enough to completely line the inside of the drum. The charger that I'm using is around thirty years old and seems to be working reasonably well ; when I was reversing the process to derust the interior of some mower fuel tanks I had to put a twenty watt light in series with it or it would shoot up to ten amps and the trip it's thermal cutout! I really like the idea of "reverse cleaning " the anodes. Share this post Link to post Share on other sites
meadowfield 1,900 #14 Posted September 22, 2015 I'd say for a huge drum you need more than 12V, I have used a 28V power supply from the aviation industry with good results. Or two 12V batteries in series... To get as close as possible to the anode I have often put the parts to be cleaned in a container and sat it straight on the anode. I too have reversed the anodes - I've also used this process to age metal when I was making reproduction hinges Share this post Link to post Share on other sites
Mister Mad Mower 64 #15 Posted September 21, 2016 You can also switch the polarity and replace the steel plate with a copper pipe or zinc sheet or old brass ornament to coat your items ( electroplate ) . A good cheat is to make up copper pipes then zinc plate them to give an origonal steel pipe look . Steel nuts and bolts with a zinc coat first then a copper / brass coat gives you a real finnishing touch at a fraction of the cost of buying solid brass / copper fixings . Especially usefull when high torque loads would strip out a brass or copper nut threads . You can go micro for individual letters etc on casings by running stainless welding rod / wire into a cotton bug / swab and applying liquid electroplating solution of the metal of choice onto the single letters etc instead of painting them .Though this method requires only around 3v or the plating can burn / blacken . The zinc coat should be polished to a shine before applying copper / brass as this gives a much better finnish . And of course , any washing rinsing should be done with new deionised water to eleviate any chemical / metals contamination from tap water . And do this in a ventilated room or better still out doors as the fumes can kill . And should you decide to coat chrome plated tools etc , then the chrome has to be removed back to the nickle plate under it .A weak solution of caustic soda and a swab set up for removal sees the chrome come right off , then Brass or copper plate will stick to the tools etc without the need for a zinc sub base . Imagine a rack of brass look spanners set up at a rally . With of course complimentary brass / copper work on your pride and joy , polished and glinting in the sun . But all there is to it is to remember that the polarity matters . That is to say the metal always travels to the negative - terminal , so to remove metal / rust attach your part to the + terminal . To add metal / electroplate , attach it to the - terminal . But the question is , do batteries run backward ? . Share this post Link to post Share on other sites
Sharri Dandy 5 #16 Posted June 25, 2020 Just showing off my wee set-up. I use it for anything covered in a rusty crust. Currently making carrot and corriander soup for dinner hence the set-up being in the kitchen😜. Ok its the prop guard from my Atco boatimpeller before it possibly goes for powdercoating with a bag of bits from other projects not decided on the finish yet. The powder coating guy only charges me a nominal £5 or £10 for each item if I do all the hard work. Wiping the sludge off and a quick wire brush isnt really hard work. In the interests of safety it is sat next to an open window. Due to the success of this set-up I have tried zinc plating but the 12v charger appears to be just a little bit harsh leaving things furry. Im going to try it again with only a couple of volts from a battery. I'll try and post the results if successful. Share this post Link to post Share on other sites
expeatfarmer 591 #17 Posted June 26, 2020 I used a 45 gallon plastic drum with a 6mm weldmesh grid against the inside wall all round, worked very well on 12 volt charger 4 amps, just out of interest I tried an old 80 amp stick welder as the power supply, the weldmesh disappeared overnight and the liquid was nearly boiling, item to be de rusted was immaculate but very black !!!! Share this post Link to post Share on other sites
Sharri Dandy 5 #18 Posted June 26, 2020 Just a bucket with a rebar cage type construction inside, water and soda crystals. I just pulled the boat impeller part out and gave it a wipe. Before and after pics attached. People have to remember this is set up, switch on, have a coffee, do some odd jobs around the house, have some food, sit n read the paper with a coffee, switch off, pull it out to check and look at in wonder, then repeat. Finish off with a rinse and a wipe. Not as fast as attacking it with an angle grinder but much more chilled and the kids are impressed with all the science stuff. Looking good so far! Share this post Link to post Share on other sites
