the showman 4,074 #3 Posted August 6, 2016 Hope to make something similar to this. 2 Triumph66 and Ian reacted to this Share this post Link to post Share on other sites
meadowfield 1,901 #7 Posted August 7, 2016 Now I'm getting ideas... Share this post Link to post Share on other sites
pmackellow 2,738 #10 Posted August 8, 2016 This is the rubber matting I was talking about Chris, its 50 inches long so should do the trick... 2 the showman and Triumph66 reacted to this Share this post Link to post Share on other sites
the showman 4,074 #12 Posted August 8, 2016 Steel ordered today for the blades, 48" x 7" x 7.5 mm, and my mate's going to roll it too, also asked him for 2 small strips to go along the bottom edge to hold the rubber on. After Rural past times Norm and I will be making 2 graderblades to take to Biddenden tractorfest, its going to be a joint build so should be a laugh just hope we can do it in time 3 Triumph66, Alan and pmackellow reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #13 Posted August 8, 2016 The strip along the bottom will serve two purposes. Primarily for me, it will act as a wear strip, with the option of fitting a rubber strip if used on concrete/tarmac etc. It could be a laugh or the end of a friendship. 3 Alan, the showman and Triumph66 reacted to this Share this post Link to post Share on other sites
Alan 1,274 #14 Posted August 8, 2016 Norm. If Chris abandons you on your visit to John's, and leaves you to find your own way back, you will know the friendship has ended. 2 Triumph66 and Stormin reacted to this Share this post Link to post Share on other sites
the showman 4,074 #15 Posted August 9, 2016 The only way he'll get abandoned is if he wonders off into the wilderness, never to be seen again. 3 Triumph66, Stormin and Alan reacted to this Share this post Link to post Share on other sites
the showman 4,074 #16 Posted August 9, 2016 Just been and collected the blades from the fabricators, made a nice job and heavy too 7 Stormin, meadowfield, Alan and 4 others reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #17 Posted August 9, 2016 Look good Chris. Heavy is good also. But before you get carried away and start drilling holes, the bottom edge of wear strip needs to be 3/8" to 1/2" below the bottom edge of the blade. 2 Triumph66 and the showman reacted to this Share this post Link to post Share on other sites
nigel 1,881 #18 Posted August 9, 2016 What's the benefit of these compared with a front blade ? Share this post Link to post Share on other sites
nigel 1,881 #22 Posted August 9, 2016 Bloke across the road from us has got a big punch that can do square holes chris 1 the showman reacted to this Share this post Link to post Share on other sites
pmackellow 2,738 #25 Posted August 9, 2016 14 minutes ago, the showman said: Rubber mat now on site thanks to Paul and Wendy. Glad to be of service Mr Showman Share this post Link to post Share on other sites
