Rocboni
    459
    7
Rocboni last won the day on August 5 2016
Rocboni had the most liked content!
About Rocboni
  • Birthday 11/25/1994
    Jedburgh, scottish borders
    Electrical and mechanical engineering, vintage machinery
4,327 profile views
  1. Rocboni
    Lathe fun
    You might find after running the lathe for a long time or under load it trips the DOL starter, unless you turned up the overload?
  2. I don't think you will benifit from doing this as you wont get in with anything to be able to press the sleeves off.
  3. Tap each one severely with hammer, Keep the wheel on its side, clamp tightly with some vice grips and single them back and forward, some will only move slightly p, you just hav to perceiver.
  4. That's the plough which came with my MG40, I always did wonder if it would actually do a good job. Time will tell, although I don't think you will wiping any prizes with it.
  5. Has it got enough power to blow material up the tube into a trailer? They normally have a big engine powered fan half way up do they not?
  6. I've always got it locally from a motor factors, Thomas Graham may have it, but you'll get it on eBay if not. Clean the area with a grinder/wire brush, degrees and apply, I repaired an escort gearbox with it which got an axle stand through it (don't ask) and it lasted until the cam belt snapped 4 years later!
  7. JB weld has always worked for me and is much easier than trying to get solder or braze to take.
  8. You would be cheaper buying 4 of the standard ones! Probably more flexible too. or a few of these http://www.ebay.co.uk/itm/12-V-Volt-Intelligent-Smart-Electronic-Battery-Charger-Car-Van-Motorbike-MP7402-/311752491484 I knew someone wirth a kubota that got used occasionally at a stables, he had a 12v solar panel on the roof of the container which he kept rigged up to keep it charges, if you do this you must use a controller regulator as at night the panel can drain the battery.
  9. Found a 4 battery one https://www.amazon.co.uk/NOCO-G4-Battery-Charger-Maintainer/dp/B0068EV26I not cheap though. It's not the one I was thinking of, I'm sure it had 10 sets.
  10. They do exist, I have seen one which had lots of sets of croc clips, I think it trickle charged them to keep them topped up, can't remember the name of it now, think it was specifically for garage situations.
  11. Can these old cars be converted to 12v, would that not be a better long term solution?
  12. Rocboni
    Typical
    But what is your next project.....
  13. Rocboni
    Typical
    So....what is it? No clues?
