Rocboni
    459
    7
Everything posted by Rocboni
  1. Rocboni
    Lathe fun
    You might find after running the lathe for a long time or under load it trips the DOL starter, unless you turned up the overload?
  2. I don't think you will benifit from doing this as you wont get in with anything to be able to press the sleeves off.
  3. Tap each one severely with hammer, Keep the wheel on its side, clamp tightly with some vice grips and single them back and forward, some will only move slightly p, you just hav to perceiver.
  4. That's the plough which came with my MG40, I always did wonder if it would actually do a good job. Time will tell, although I don't think you will wiping any prizes with it.
  5. Has it got enough power to blow material up the tube into a trailer? They normally have a big engine powered fan half way up do they not?
  6. I've always got it locally from a motor factors, Thomas Graham may have it, but you'll get it on eBay if not. Clean the area with a grinder/wire brush, degrees and apply, I repaired an escort gearbox with it which got an axle stand through it (don't ask) and it lasted until the cam belt snapped 4 years later!
  7. JB weld has always worked for me and is much easier than trying to get solder or braze to take.
  8. You would be cheaper buying 4 of the standard ones! Probably more flexible too. or a few of these http://www.ebay.co.uk/itm/12-V-Volt-Intelligent-Smart-Electronic-Battery-Charger-Car-Van-Motorbike-MP7402-/311752491484 I knew someone wirth a kubota that got used occasionally at a stables, he had a 12v solar panel on the roof of the container which he kept rigged up to keep it charges, if you do this you must use a controller regulator as at night the panel can drain the battery.
  9. Found a 4 battery one https://www.amazon.co.uk/NOCO-G4-Battery-Charger-Maintainer/dp/B0068EV26I not cheap though. It's not the one I was thinking of, I'm sure it had 10 sets.
  10. They do exist, I have seen one which had lots of sets of croc clips, I think it trickle charged them to keep them topped up, can't remember the name of it now, think it was specifically for garage situations.
  11. Can these old cars be converted to 12v, would that not be a better long term solution?
  12. Rocboni
    Typical
    But what is your next project.....
  13. Rocboni
    Typical
    So....what is it? No clues?
  14. Love these old cars and would like to own one, I was bidding on a teal Bugatti last month but missed out.
  15. Fantastic bandsaw, the loop does look like original as it has the crimp ferrules, however it should never of had this, the only reason I can see is if some one wired it without a neutral supply and was pulling a reference to ground so that the control circuit works, an electrician would not do this, its a big no no! Very dodgy. I would suggest you snip the ferrules off, strip the cable and put it back into the DIN rail terminals, you stick a screwdriver into the square hole to release the clamp.
  16. There's no way that the earth should be connected to the neutral at the machine, (although your earth is basically your Neutral at the DNO cut out) this is what will be causing the tripping as the RCD will be seeing this. meadowfeild, Saw may require a Neutral for the control circuit if modern contractors ect are used. If just a straight DOL starter only 3 phase and earth.
  17. Must have an Earth fault, it will run off a generator fine as it has no RCD? Along with your old workshop? Does the bandsaw have a Neutral, I'm guessing a neutral to earth fault as live to earth would result in a bang! Try to isolate sectons of the circuit.
  18. Missing them already.....always liked the Mg40 for some reason it was one of my favourites.
  19. I'm with Neil, somthing jammed in final drive gear between idler gear, but you would think you could free it by going the opposite direction!
  20. More pictures which dad took. Jonathan pushing the crawler up the ramp😀
  21. You'll have to call in to give him a hand to unload it all!
  22. Well, today Jonathan came for the skimmer, I also sold him my Mg40 due to it just being in storage. Loading the skimmer went smoothly much to my relief, I was worried that we couldn't get it on, but I lifted the front and jammed a peice of wood between machine and auger which gave it some ground clearance. No pictures as I was driving, I'm sure Jonathan will have one or two.
