madmatt01
    137
madmatt01 last won the day on June 26 2019
madmatt01 had the most liked content!
About madmatt01
    dorset
5,058 profile views
  1. Glad to hear it is still about. I saw photos of it at Netley after you got it but none since. We did Netley this year and i did keep an eye out. We have lost a wheel and currently showing a bonser truck
  2. Hi Ben, They are quite a heavy machine but not to bad. I would guess 3 - 400 kg. Maybe half ton with the cutters on. Very simple design and good fun to work on. I sold mine just before Christmas. With the large rear tractor wheels the chap i sold it to just got it in the back of a Nissan pick up truck.
  3. Been a while since I have been on here. A house move, baby girl, new job e.t.c e.t.c. But myself and pops have made another Bolens purchase! We managed to get a nicely restored bolens 1000 of a neighbour on the weekend that just needs a tiny once over. Variety of attatchments (most home made) bit there is a tiller, roller, lawn rake, some sort of plough / grader. Nice little tipper trailer as Well. We have also been told there is a plough, sprayer and manual to pick up to go with it. Unfortunately I have used up all my allowed photo space so need to renew my membership. Andrew feel free to pinch the pics of the FB! The only thing I need to get for it is a push starter button. Thanks all!
  4. Looking good. Best thing would be get then out in the sunshine and start tinkering. Download engine manuals and get them running then work your way through them. The rear brake set up.is the same as.morris minor
  5. Iv just finished mine. These later became known as nicholson turfmaster. Iv not come across a a place to buy parts... I was lucky to.have most bits with mine. I done a full strip down and rebuild with some changes i.e larger rear wheels.
  6. Must keep my eye out at the show for some front lights...
  7. Carb changed... running lovely. Finished off the last few odds and sods. It's not 100% how I want it but close enough. Now ready for a quick clean and il be sorted
  8. Nearly there... carb leaking fuel back out the inlet. Was set up for gravity fed tank but iv fitted pump. Over fueling I pressume now. Swap carbs over now Old man having a test run....
  9. Bought another engine - k321. Fresh oil and fired straight up Finished rigging her up properly tonight the just need to get a matching pulley
  10. Hopefully going to pick up a k321 on a points set up today / tomorrow Fingers crossed
  11. When I bought the tractor it has the trigger wired to +. I think I may have burnt either the trigger module or the ignition coil. It provides its own energy behind the flywheel. Battery is just to turn over Matt
  12. On this machine there isn't any safety wires. It is simply wired up as followed.. I'm worried the problem lies with the trigger module or ignition coil as can't find these parts anywhere
  13. Yes.... dad machined a template at work and we re drilled to fit 6 stud. Sits well. Just hope I can sort engine. We have re wired as per online diagram with no luck. This solid state ignition is ment to be ultra relIable.... Guess il have to open my wallet
  14. So today I have started to rebuild the horwool. Got the engine in place and rigged up the wiring. We got it to fire a few times but now nothing Can anone give me any pointers to look at.. Kohler k301s. It doesn't appear to have points. It has an external coil and breaker I think. Have checked it with multi meter... everything seems to be responding except the spark plug 😐 Il include some photos... Colour scheme the wifes choice. ..
