Here's some info on the recoil. Click on the picture
Heat the spring cherry red only at the bend and it will bend without any cracks or cracking off.
You can find diagrams in the manual section.. Scroll down to 1965. The only thing different may be the shape on the end of the crankshaft.
Check the air filter for old foam and remove it if there is some or will get sucked into the carb and engine.
You'll need a carb diaphragm. Probably a tank clean and change the fuel lines.
If it doesn't have spark you will need to clean the points contacts. It's under the flywheel and you will see the cover.
Putting a few drops of old school DOT brake fluid on the crank seals will usually swell them enough to seal without the need to dis-assemble the entire engine to replace seals.
A leak down test can be done by removing the muffler and attaching a blown up party balloon to the exhaust collector. The piston should be at TDC and the spark plug in place. You will hear the air hiss out through any seals that are not sealing enough as the balloon pushes air into the crank case. Even new seals will leak air but just a little.
Mix oil and fuel at 32:1 with a good quality modern 2 stroke oil designed for air cooled engines. Outboard oil ashes off different and shouldn't be used.
I'll get a piece out to you
Yes that's the same but mine is a repop that I built a few years ago. $1500 + is too steep for little collectables.
Here's a link of the thread.
I have some blue tempered spring sheet metal .003" I can send you. I was making my own springs out of it and found that grinding the center out with a thin cut off wheel worked much better than trying to cut it out. Then cut the outside shape. Just don't grin hard to heat up the metal or it will loose it's spring properties.
50" x 3" can make A LOT of springs.
Surprising that would break a spring.
I pulled that one from one of my good carbs. I'd need to look around for another one if I even have one.
. A while back I was making my own out of spring material sheet because they are pretty scarce now.
It's a check valve. Make sure you can blow through it in one direction (Flow direction). It may be clogged up from old 2 stroke oil.
If it's clogged you can leave it off
I don't remember ever hearing of a Ranger. It's basically the same thing as a Mustang saw except for the chain guard is a little different. We see those minor changes on lots of different tools that have different brand names but are basically the same thing.
The recoil/blower housing is a factory replacement. That tan color paint without a label was what the factory sent out.
I have a Chip-A-Saw like that one and also another one that looks completely different. Looks like this
That thing looks to be a great condition.
The diaphragm in the carb will need to be changed. When they get stiff it won't prime or pump fuel. And clean the carb. You can follow the pinned carb tutorial. Shoot me a PM for a diaphragm.
Check for spark. If no spark you will need to remove the flywheel then the points cover to clean the contacts on the points.
Obviously clean the tank too
Yes that's the engine shut down
I can help you with a carb diaphragm.
Most exhaust gaskets can just be re-used unless they were damaged during disassembly. I can probably find a used set of gaskets
That information kinda mirrors the O&R engines
Screw from the back early engines
Screw on from the front middle year engines
Then the screw on starters about 1970
Took a look around and have some spare tools I'd consider letting go of. I also found a bar and chain that would fit that Ford saw if you haven't found one.
C/Saw Circular saw
Hedge Trimmer
Amp Champ generator (Completely rebuilt engine)
Tiny Tiger 300 generator (Completely rebuilt engine)
Snow Blower (Completely rebuilt engine and gear box)
? Aquabug Outboard
? Chicken Power bicycle engine
If you need something I'd search through and see if I have it.
I have a bunch of used parts and laser cut diaphragms but it would be too much work to go through it all and make a list just for window shopping.
Probably have some doubles of some tools I'd consider letting go. Circular saw, Amp Champ generator, Tiny Tiger generator.
Those cylinder cooling fins and the air cleaners are some of the most common missing parts so your best bet is to keep an eye out on ebay as they do pop up every once in a while.
Search "Orline chainsaw" for the other parts too. Chain and throttle cable. The FORD saw is just a branded Orline saw so the parts are the same, just a different color
You will also need a new carb diaphragm too.
If you choose to do it, the crank seals can be somewhat rejuvenated by soaking them in place with a few drops of old school brake DOT3 brake fluid. Synthetic will not work. Carb cleaner spray can work too but not as well plus it washes off the lubrication oils so it'll start dry unless you oil them afterwards and before starting it.
wind the spring and keep pulling on the tail to cinch it tighter and smaller. Repeat, repeat, repeat until it's wound tight and will fit in the holder.
Hold the spring down with your thumb at the holder opening and pic out the holder with something sharp. Release the thumb pressure slowly so the spring unwinds slowly
Maybe it's ground a negative wire to the case and the positive post ??? 2 posts are 12v.
Do you have a multi meter if it's not in the manual how to achieve the 6v? I breezed through it but didn't see anything.
Wish @factory David was still active. He always seemed to have the answers for stuff like this.
