the showman 4,074 #1 Posted April 6, 2016 Got me Raider 12 back from Johns yesterday after its tour of duty at his place over the last few weeks. Decided to do a few jobs to it and the first thing was a front weight carrier made from some angle iron and an old mule drive so i can unclip it when not in use, i made it to take 2 weights but I think one will be enough. I'll let the photos speak for themselves. 4 slf-uk, Alan, ranger and 1 other reacted to this Share this post Link to post Share on other sites
diggerjames 543 #2 Posted April 6, 2016 Good idea Chris Share this post Link to post Share on other sites
Stormin 4,458 #3 Posted April 6, 2016 Looks ok. Similar to what I've done. Share this post Link to post Share on other sites
meadowfield 1,901 #4 Posted April 6, 2016 Nice work Chris Share this post Link to post Share on other sites
Stormin 4,458 #5 Posted April 6, 2016 BTW. Like the Marks & Spencers weights. 1 Joe the small engine man reacted to this Share this post Link to post Share on other sites
harryt 281 #6 Posted April 6, 2016 Looks good and strong Share this post Link to post Share on other sites
the showman 4,074 #7 Posted April 6, 2016 Here's a couple more 3 ranger, Joe the small engine man and diggerjames reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #8 Posted April 6, 2016 Here's mine. 2 Joe the small engine man and diggerjames reacted to this Share this post Link to post Share on other sites
the showman 4,074 #9 Posted April 6, 2016 What weight is it Norm, looks like it came out of Carols washing machine Share this post Link to post Share on other sites
Stormin 4,458 #10 Posted April 6, 2016 2 minutes ago, the showman said: What weight is it Norm, looks like it came out of Carols washing machine Heavy! I keep meaning to take it up to the farm and weigh it. Think it's off one of those fitness machines. Share this post Link to post Share on other sites
the showman 4,074 #11 Posted April 6, 2016 The other thing i did today is to start sorting my sight poles. I found some stainless thick wall 1" tube, cut it down to 5ft 6" and painted the first coat of red. it wont worp or go rusty 2 Triumph66 and ranger reacted to this Share this post Link to post Share on other sites
slf-uk 914 #12 Posted April 6, 2016 Great work on the weight frame and poles. You could use those poles for horse jumping too :-)) Iain 1 the showman reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #13 Posted April 6, 2016 7 minutes ago, slf-uk said: You could use those poles for horse jumping too :-)) Iain I can just see him pole vaulting over his horses. 4 Alan, the showman, ranger and 1 other reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #14 Posted April 6, 2016 25 minutes ago, the showman said: The other thing i did today is to start sorting my sight poles. I found some stainless thick wall 1" tube, cut it down to 5ft 6" and painted the first coat of red. it wont worp or go rusty You could do with points on one end. Share this post Link to post Share on other sites
nigel 1,881 #15 Posted April 6, 2016 You won't lose them in a hurry chris Share this post Link to post Share on other sites
the showman 4,074 #16 Posted April 6, 2016 How can i put points on tube Share this post Link to post Share on other sites
Stormin 4,458 #17 Posted April 6, 2016 5 minutes ago, the showman said: How can i put points on tube You've got a lathe. Turn some inserts with a shoulder to butt against the pipe end and a point on one end. Then drill and pin them to stop them falling out. Simples! You'll also need some way to carry them. Share this post Link to post Share on other sites
the showman 4,074 #18 Posted April 6, 2016 Carry them ? I gonna stick them in the ground, Steves coming he can carry them Share this post Link to post Share on other sites
Stormin 4,458 #19 Posted April 6, 2016 Don't forget a spirit level. They need to be perfectly vertical to line up properly. Share this post Link to post Share on other sites
ranger 373 #20 Posted April 6, 2016 2 hours ago, the showman said: How can i put points on tube cut 3 triangles out of the end of the pole, base of the triangle at the end, and bash the points left on the pole together with a blob of weld to hold them. Share this post Link to post Share on other sites
ranger 373 #21 Posted April 6, 2016 1 hour ago, Stormin said: Don't forget a spirit level. They need to be perfectly vertical to line up properly. not if they all lean at the same angle 1 Stormin reacted to this Share this post Link to post Share on other sites
the showman 4,074 #22 Posted April 7, 2016 Had a go at changing the front wide wheels to narrow ones today. I found a pair of wheels at Johns with back plates and drums which im not using ( don't think the wheelhorse needs front brakes ) dont know what they were from but were painted a sort of air force blue. with a bit of machining in the lathe 2 sleeves were made and thick washers and a bit of drilling and tapping. heres how far ive got today. 3 Alan, Stormin and nigel reacted to this Share this post Link to post Share on other sites
nigel 1,881 #23 Posted April 7, 2016 Looking very good chris 1 the showman reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #24 Posted April 7, 2016 Nice job Chris. 1 the showman reacted to this Share this post Link to post Share on other sites
meadowfield 1,901 #25 Posted April 7, 2016 Good work 1 the showman reacted to this Share this post Link to post Share on other sites
