WestwoodW8Gazelle 51 #1 Posted September 7, 2017 Hi all, and of course Westwood fans that may be interested... I have bought a 1978 W8 Westwood gazelle 'pale face', starts on the key. 8 horsepower, column gear change. I have recently replaced points and condenser which seemed to of solved the problem, as before when the mower ran for a few minutes the engine used to cut out. I have also replaced air filter for the first time in 39 long years! 😂 I have also given the engine numerous amounts of oil changes as when I bought the mower last year there was lots of residue like sludge left in the oil. After all the work, engine starts and runs lovely. ☺ About a month ago... I was cutting grass and tried using the clutch and the clutch wouldn't stop the machine!!! So had to shut off the machine before I nearly collided. 😂😨 Only to find the drive belt had slipped off the pulley. This has made me by a new drive belt with two new pulleys. The pulleys arrived but wasn't convinced they were the right size, so I sent them back. Kept the drive belt. Unfortunately I am having troubles with finding the right size pulleys for the mower. If anyone has a pair of unused original metal Westwood Gazelle pulleys for sale, or know where to find some. Please tell me. Thanks. Here's some pics of my Westwood last year. 3 4x4forks, Triumph66 and WestwoodGazelle reacted to this Share this post Link to post Share on other sites
HeadExam 1,783 #2 Posted September 8, 2017 If you can get me the sizes of the pulleys (bore, height, width of V, diameter, pictures would be best with measurements) I can cross reference them to part numbers you can use locally. The part numbers used by Westwood unfortunately aren't the same as used by the pulley distributor/manufacturers . 1 Triumph66 reacted to this Share this post Link to post Share on other sites
Chris 642 #3 Posted September 8, 2017 Were westwoods built in the 70s?? I would have guessed 1988 Share this post Link to post Share on other sites
Wristpin 400 #4 Posted September 8, 2017 (edited) Yes, Westwoods were made in the 70s . Not sure how far back for the tractor shaped ones but they were definitely around pre 80s. I had a Lawnbug early 70s or even late 60s!!!! We used to see the trans drive belt dropped off the big pulley on the top of the trans and used to fit a peg keeper down from above just to stop it falling clear of the pulley when de-clutched. Did you post this query somewhere else a while back? In answer to whoever did I posted the part numbers for two pulley mod kits for the "zig zag pulleys that did the de-clutching. I'll dig them out again and add them to this post. EDIT 3230 and 5823 Both on our stock file as "idler pulley mod kits" .Obviously meant something back in the day but may have no relevance to your question! Edited September 8, 2017 by Wristpin additional info 1 WestwoodW8Gazelle reacted to this Share this post Link to post Share on other sites
WestwoodGazelle 103 #5 Posted September 8, 2017 It's a really nice looking machine I hope you get your pulley sorted out! 1 WestwoodW8Gazelle reacted to this Share this post Link to post Share on other sites
HeadExam 1,783 #6 Posted September 9, 2017 I would be surprised if the pulleys are not the same as either AYP , MTD, or Murray models of the same vintage Share this post Link to post Share on other sites
WestwoodW8Gazelle 51 #7 Posted September 9, 2017 On 9/8/2017 at 4:37 AM, HeadExam said: If you can get me the sizes of the pulleys (bore, height, width of V, diameter, pictures would be best with measurements) I can cross reference them to part numbers you can use locally. The part numbers used by Westwood unfortunately aren't the same as used by the pulley distributor/manufacturers . Hi, outside measurements of pulley is 2 1/2 inches from outside pulley. The diameter is 2 inches. Thanks for your reply. Much appreciated! 😀 Share this post Link to post Share on other sites
Wristpin 400 #8 Posted September 9, 2017 You may find what you need here https://www.dropbox.com/s/joaarxsg6kgm5ls/CS Pulley assortment0001.pdf?dl=0 Share this post Link to post Share on other sites
pmackellow 2,738 #9 Posted September 10, 2017 On 9/8/2017 at 5:38 PM, Chris said: Were westwoods built in the 70s?? I would have guessed 1988 I've got a 1973 advert for the Lawnbug Chris so I would have thought Westwood tractors started in the early 70's ? Share this post Link to post Share on other sites
HeadExam 1,783 #10 Posted September 10, 2017 On 9/9/2017 at 4:43 PM, WestwoodW8Gazelle said: Hi, outside measurements of pulley is 2 1/2 inches from outside pulley. The diameter is 2 inches. Thanks for your reply. Much appreciated! 😀 Pulleys and idlers need the measurements of the diameter, the width, the bore, and the size and type of the channel. Also the style and size of the center bearing area, whether protruding or recessed, needs to be the same. A picture or diagram is the only real way to assure a proper fit. The original part number may also lead to a cross reference part number from others that have searched for replacements on the internet Share this post Link to post Share on other sites
WestwoodW8Gazelle 51 #11 Posted September 10, 2017 (edited) On 9/10/2017 at 1:41 PM, HeadExam said: Pulleys and idlers need the measurements of the diameter, the width, the bore, and the size and type of the channel. Also the style and size of the center bearing area, whether protruding or recessed, needs to be the same. A picture or diagram is the only real way to assure a proper fit. The original part number may also lead to a cross reference part number from others that have searched for replacements on the internet Hi here's some pictures of the pulley. I am not sure what you mean by the bore. Thanks for the reply. 😀 I hope these pictures are clear enough... Thanks. Edited September 10, 2017 by WestwoodW8Gazelle Share this post Link to post Share on other sites
Stormin 4,458 #12 Posted September 10, 2017 Bore is the hole through the centre. Where about are you located? I broke a Gazelle a few years back. I kept some of the pulleys and I think I have one like that. I'll check tomorrow. Share this post Link to post Share on other sites
HeadExam 1,783 #13 Posted September 10, 2017 On 9/10/2017 at 6:11 PM, WestwoodW8Gazelle said: Hi here's some pictures of the pulley. I am not sure what you mean by the bore. Thanks for the reply. 😀 I hope these pictures are clear enough... Thanks. The only thing to watch out for on this fairly common idler (in size) is the the protruding bearing/center offset on one side, it needs to have the very same offset or a spacer must be used to create one. It appears to be a AYP idler pulley p/n AYP 4702H or AYP 66048 (same) Stens part number 280-024. which has a 3/8" bore (hole, 2-1/2" outside diameter, and 1" height (distance across the idler). i believe this part also has the same offset on one side, 10 bucks new around here Share this post Link to post Share on other sites
Stormin 4,458 #14 Posted September 10, 2017 10 bucks?? That's deer. 1 HeadExam reacted to this Share this post Link to post Share on other sites
WestwoodW8Gazelle 51 #15 Posted September 11, 2017 On 9/10/2017 at 8:34 PM, HeadExam said: The only thing to watch out for on this fairly common idler (in size) is the the protruding bearing/center offset on one side, it needs to have the very same offset or a spacer must be used to create one. It appears to be a AYP idler pulley p/n AYP 4702H or AYP 66048 (same) Stens part number 280-024. which has a 3/8" bore (hole, 2-1/2" outside diameter, and 1" height (distance across the idler). i believe this part also has the same offset on one side, 10 bucks new around here Thank-you very much, excellent news about the pulleys. I have found the pulleys from new online using your part numbers. It's great, as now I can get the old girl back up and running! Haha. Thanks. 😃👍 On 9/10/2017 at 7:23 PM, Stormin said: Bore is the hole through the centre. Where about are you located? I broke a Gazelle a few years back. I kept some of the pulleys and I think I have one like that. I'll check tomorrow. Thanks. Haha. Its good to know some extra knowledge. Using some part numbers kindly provided by Head exam I will try and look online as some pulleys came up new same as my pulley. Thanks for the offer, if I can't find the pulleys, I may offer you something for the breaker pulleys if they are still available. Thanks for the help. 😃👍 On 9/10/2017 at 11:12 AM, pmackellow said: I've got a 1973 advert for the Lawnbug Chris so I would have thought Westwood tractors started in the early 70's ? Wow! Really? I haven't seen any adverts for Westwood early mowers. I have one for my Westwood W8 but only printed it off from Google. Haha. 😂 Would love to see a picture of the advert! Sounds interesting. Thanks. 😃 On 9/9/2017 at 10:11 PM, Wristpin said: You may find what you need here https://www.dropbox.com/s/joaarxsg6kgm5ls/CS Pulley assortment0001.pdf?dl=0 Thanks. I will check it out! 😃 Share this post Link to post Share on other sites
pmackellow 2,738 #16 Posted September 11, 2017 Here's a photo of the 1973 advert Reading through my literature I also found a brochure from 1970, so even earlier ! 1 HeadExam reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #17 Posted September 11, 2017 I like the Estate Car bit. Had a few estate cars but never one like that. Only £165 for the delux version as well. Share this post Link to post Share on other sites
pmackellow 2,738 #18 Posted September 11, 2017 That was for the 5hp Norm, that's the quick one !! 1 WestwoodW8Gazelle reacted to this Share this post Link to post Share on other sites
WestwoodW8Gazelle 51 #19 Posted September 11, 2017 On 9/11/2017 at 6:35 PM, pmackellow said: Here's a photo of the 1973 advert Reading through my literature I also found a brochure from 1970, so even earlier ! Thanks! That's the first time I have seen an official old Westwood advertising!! Haha. Now I wish I kept my old lawnbug. I sold it for £10!! This was before I was into Westwood mowers and I saw nothing of it at the time unfortunately. Share this post Link to post Share on other sites
pmackellow 2,738 #20 Posted September 11, 2017 Here's mine when I bought it earlier this year and what it looks like so far... Share this post Link to post Share on other sites
HeadExam 1,783 #21 Posted September 11, 2017 Great advert photos, thanks for sharing. Share this post Link to post Share on other sites
Alan 1,273 #22 Posted September 11, 2017 There was a Lawnbug at John's place. Sold it on eBay for £100 long before the big clear out started. Not sure what model but remember it was green with a white engine. Non runner and scruffy condition. Share this post Link to post Share on other sites
WestwoodW8Gazelle 51 #23 Posted September 12, 2017 On 9/11/2017 at 7:01 PM, pmackellow said: Wow that's one early bug. Looks really cool. Just like stepping back in time!! Haha. Sorry if my comments are a little weird. (I still don't know how to comment without 'quoting' all of the post I am replying to. 😂 Share this post Link to post Share on other sites
Stormin 4,458 #24 Posted September 12, 2017 Don't click on the quote +. Just type your reply. 1 Anglo Traction reacted to this Share this post Link to post Share on other sites
WestwoodW8Gazelle 51 #25 Posted September 14, 2017 Ok, thanks. 😃 Share this post Link to post Share on other sites
