Stormin 4,458 #403 Posted November 27, 2015 Wired things up today. Switch goes straight to the battery for now. It will be wired via the ignition switch eventually and fused. Filling the pump with hydraulic oil took some time. Due to where the pump is, the breather/filler is only accessible with an oil can. Finally test time. Much to my delight the hitch went up and down a treat. So on with the plough. Wouldn't lift it. After a bit of thinking, I decided to reposition the ram to fulcrum. Below is where it was. As you can see, not much leverage. So, finding a bit of flat bar I bolted it to the arm, so it was extended. Ram fitted in after much fiddling. Plough back on and not holding out much hope, I tried again with baited breath. Can't seem to get the short video on here, so I'll put it in the video section. Just remembered. I have to go via U tube. https://youtu.be/YrjilSgSi3o  2 ranger and the showman reacted to this Share this post Link to post Share on other sites
C-101plowerpower 548 #404 Posted November 27, 2015 is the pressure relieve set right? 4 nigel, Ian, the showman and 1 other reacted to this Share this post Link to post Share on other sites
meadowfield 1,901 #406 Posted November 27, 2015 Great work Norm Share this post Link to post Share on other sites
nigel 1,881 #410 Posted November 30, 2015 it will be worth it norm, when your ploughing next with the showman you will wop his arse Share this post Link to post Share on other sites
nigel 1,881 #416 Posted December 2, 2015 great job norm Share this post Link to post Share on other sites
meadowfield 1,901 #425 Posted December 8, 2015 Like Doug says, the cylinder is more efficient pushing. The rod effectively reduces power in one direction. Have you thought of mounting it like they were originally? I.e. On the left foot rest bar, then it pushes against a rocker on the end of the lift handle... Share this post Link to post Share on other sites
