Stormin 4,458 #27 Posted January 29, 2016 There's certainly no shortage of variety working at J. Cox Ransomes Specialists. 3 nigel, hpearce and Triumph66 reacted to this Share this post Link to post Share on other sites
expeatfarmer 591 #28 Posted January 29, 2016 Assistance very much appreciated Norm. 3 Stormin, diggerjames and nigel reacted to this Share this post Link to post Share on other sites
Wristpin 399 #31 Posted January 29, 2016 There's certainly no shortage of variety working at J. Cox Ransomes Specialists. Reminds me of Cat Stevens's 1966 hit Matthew ans Sons. "the work's never done"! 1 nigel reacted to this Share this post Link to post Share on other sites
expeatfarmer 591 #33 Posted February 1, 2016 Wired up ignition system, sorted throttle cable Norm fitted tyres wheels and chains. Ready to try starting it in the morning, a few fuel leaks to sort first. New Dunlop Industrial tyres look good , not sure what pressure to inflate them to. 4 nigel, Alan, the showman and 1 other reacted to this Share this post Link to post Share on other sites
expeatfarmer 591 #39 Posted February 3, 2016 Checked the exhaust valve clearance which was a bit tight and then noticed that the rocker arm bushes were worn which makes setting the valve clearance impossible. I then noticed that the valve spring retainer was a non standard item, the Drayton engine has two exhaust valve springs of unequal length the outer retains pressure on the rocker arm at all times, clearance is set using a narrow feeler through a slot in the upper spring retainer. This head had both springs held down by a standard collet collar, looks as if the previous owner had adapted a non standard valve which clearly worked but not properly which may explain why the diesel engine was removed and a petrol engine fitted. Fortunately I have a couple of spare brand new heads complete with valves so as a minor diversion I have fitted a new cylinder head. I have done this a few times before so took a guess at the gasket thickness and peeled off a few layers before I refitted the head leaving a piece of lead solder on top of the piston, Torqued the head down and turned the engine over a couple of time by hand, remove the head and measure the squished solder thickness luckily it was 0.9mm on the first go so took out the solder refitted the head and off we go. I was extremely lucky because these heads have a section that sits about 3/4" into the liner which is steel against an alloy head!! they can be absolute pigs to remove, usually evidenced by broken cooling fins on the head and barrel where levers have been applied in the past. Before now I have had to resort to removing head and barrel together and thumping the whole thing up and down on a wooden post with lots of heat to break the head free. This one popped off as soon as I undid the head bolts a sure sign it has been off before and not run much since. Picture on the right is the new head showing the slot for setting clearance in the outer spring cap. 1 nigel reacted to this Share this post Link to post Share on other sites
expeatfarmer 591 #44 Posted February 4, 2016 Changed the governor no change, checked the spill timing seemed ok. Removed the new head and the barrel fitted a brand new piston and barrel started it up and still the same!!!!!! Seems I am destined to explore the nth degree of set up on all my engines will fiddle a bit more in the morning, good thing about this engine is the electric start at least turning it over is not killing me! Good old Norm re assembled the brake bands on the MG40N and we got that running today, Norman took it for a test drive. 2 mg_rob and diggerjames reacted to this Share this post Link to post Share on other sites
nigel 1,874 #47 Posted February 4, 2016 Where's his L plates Share this post Link to post Share on other sites
Stormin 4,458 #48 Posted February 4, 2016 I'd be in serious trouble if I did, Rhys. She still wont let me forget about selling the Spitfire. They're simple to drive, Nigel. Even you could manage. 2 Rocboni and Alan reacted to this Share this post Link to post Share on other sites
