Tom
New addition - Wheel horse 312-8
I'm sure you guys know I like pictures so here are a few more for you!
Hauling some wood for the fire:
After a quick wash:
I also got the deck out for a wash:
After it had been washed and oiled:
I'm still unsure whether to put the deck away in storage or sell it, I will never use it...
Tom
Tom, it's always good to see someone using thier machinery and looking after it as well. Good on you. I would have that deck myself if I had a Å´heel Horse that is!
I can't believe that Iain bought your WH, he must be colour blind or you told him it was a Bolens in disguise! He's very pleased with it.
Nice to see a tractor working ;) Looks cleaner than my 312-8 at the moment :P Thanks for sharing the pics.
Andrew you could extend your collecting to Wheel Horses and buy my 312-8 complete with deck end of this year beginning of next when i've finished needing two tractors ;)
Tom.. Remind me Monday about the missing snowplow bolt.. I found it the other day...  I also found the cutting deck belt cover...
It's amazing how things can hide away in a workshop!
Thanks for all your positive comments, I really appreciate it! I love pottering around on it but it always feels better when you have a job to do with it.
I'll try to remind you Monday Ian, hopefully I won't forget either :D
Tom
Daniel,
Don't you start on my adding to my collecting habit; I am in enough trouble as it is! In any case, my next one is a Cub Cadet (thanks Chris) or a Gutbrod or Bolens 600 or a very early Å´heel Horse but only when I have got the other two Safely home. I think you will be smitten by the Bolens bug once you have worked your magic on the 1254....
Cheers
Tom
That is a great tractor, Tom. Look better in the flesh than the pictures :thumbs:
  On 3/28/2015 at 9:09 PM, Triumph66 said:
Daniel,
Cheers
Andrew, I think you need a Wheelhorse for your collection, if you need to sell your Bolens to fund it I am sure I could help :)
Iain, I can counteract you generous offer by saying if you need to appease your wife with reducing your collection I can assist by buying several of your Bolens and the Cub Cadet !
Evening all,
I have been clearing out and re-doing my workshop and have finally finished painting the floor and have started moving back in and couldn't resist getting the 312-8 in for some maintenance.
On the bench:
I am installing a slot hitch so I stole the wire conduit off of my C-141 and installed it on this:
Slot hitch in place, I'm just waiting on some small D shackles:
I also removed the front wheel and spindles, de-greased them in my new parts washer, and put it all back together :D Bearings were all OK and the wheel spin much better now and the steering is also better. No pictures of it disassembled but here it is reassembled!!
Parts pile growing!
I have still yet to do an engine service, replace transmission oil, weld up hi-low lever, finish off slot hitch and whatever else I can remember! Thanks for looking.
Tom
All back together now Norm :D
I had an afternoon on it today, got the hitch all connected up after getting some stainless steel D shackles. I also welded the high - low lever up; it feels so good to have low range back!!
Hitch in place:
Lever back in place :D
All back together:
Back on the bench ready for an engine service and to flush out the transmission in the next few days..
It's getting there now, I also have a plough lined up for it which should be installed in the next few weeks which I can hopefully put to work at Rural past times event. Thanks for looking.
Tom
Hi all,
I have been a bit distracted with my new wheel horse however the 312-8 had it's service and went back into the tractor shed. I haven't really used it for about 3 weeks but it started right up however wouldn't run without some choke, I'm presuming there is some dirt in the carb or something. I actually got it out to test a trailer I quickly banged together. It was an old wheel barrow that was destined for the scrap yard but after a bit of cutting and welding we had a trailer with a drawbar. It's a nice size to haul wood down to the house with!
Tom
Tom,
I had the chance to have a look through my WH parts and found this
I have no idea if it works or not and it does need a clean. If this is the type you are looking for I will put it in the truck for next Tuesday, unless you need it sooner.
Cost = FOC, better on your tractor doing some good than collecting dust on my shelf
Iain
Hi Iain,
That's perfect, I would appreciate if you could bring it next Tuesday, thank you so much. We will have a square up on Tuesday too, I can't give you nothing for it!!
Tom
  On 2/8/2016 at 8:22 PM, Chris said:
Looking well Tom
Supprised you have not sold this one also ;)  B)
This ones staying, for now ;)
  On 2/8/2016 at 8:23 PM, harryt said:
Looks like a good worker and a strong tractor.
Thank you, it certainly is a good worker, a real tough machine.
Tom
