Sammoore13bolens1053
    60
About Sammoore13bolens1053
4,724 profile views
  1. Job weld do a specific gas tank repair bond. I seen it in bass pro shops in the states few weeks back
  2. What storm in said, then probably the points, probably not the plug, put a new one in it
  3. Ahhh you can b that bad! Mine doesn’t look to bad. For a switch contact Brian, on bolenspartsandsupplies.com
  4. Hi, mine was done with a on off switch for ignition, and a push switch to start. Would only start when the switch was on. I’m alright with wiring, and if your any good at wiring, you could do my setup
  5. Sachs dolmar, the chainsaw brand perhaps? They used to make great machines, rubbish now
  6. I have one of them. One the same, exact same I can’t remebre the engine. I have one that’s a ransomed from about 1950 something. A bsa powered one, a jap engine one and one the same as that
  7. Oh, so that sleeve hitch won’t fit a tube frame? What’s it for? Oopsies about the advertising, at least someone will get it...
  8. Hi everyone, I spotted this one ebay but the buyer won’t spilt the stuff. If anyone purchases, I’m interested in the Plow and sleeve hitch. Up to 40-50 pounds plus shipping. Thanks in advance
  9. Id say buy new ones, they have been exposed for years, and if working will not work for long, solenoid should make a click noise when the key it turned to The one position
  10. This is one big job. Get that wiring sorted. Go to bolenspartsandsupplies.com he’s a site sponsor over at gttalk. You probably need a new key switch, new solenoid, new wiring, new ammeter. Get that rust cleaned off and see if any bad damage. See how your pulley is doing, don’t look to pretty. You could go onto ebay and get a whole shopping list off used parts, just search “bolens” under all categories and then cross reference the part numbers you see to the part manual for your 850. Also try tubeframes.com and bolenspartsandsupplies.com and see all the parts you could possibly use And does your pro go into gear? You probably need a new coil as you said it wasn’t sparking, your clutch is probably frozen too. So it’ll need dismantled And I don’t think you’ll get any spark without a working voltage regulator, but send bolens 1000 a pm on gttalk, he’s the owner of bolens parts and supplies
