meadowfield 1,900 #1 Posted August 15, 2016 Whilst you were all enjoying yourselves at rpt, I took some time away from diy and plumbing to have a go at something I've been thinking of for a few years. wheel horses don't shift gear on the move well, and often you might need to slow down a bit for some power, or speed up. so with the idea of Powershift on the old internationals I spent about 12 hours at the lathe and came up with this. A split pulley system allowing a 20% increase in speed at the pull of a lever. So that's 12 forward speeds - and another gear lever to find a place for. Of course if the system works... hopefully get get to have another look when I get home on Friday. 4 ranger, HeadExam, Stormin and 1 other reacted to this Share this post Link to post Share on other sites
C-101plowerpower 548 #2 Posted August 15, 2016 1 hour ago, meadowfield said: Whilst you were all enjoying yourselves at rpt, I took some time away from diy and plumbing to have a go at something I've been thinking of for a few years. wheel horses don't shift gear on the move well, and often you might need to slow down a bit for some power, or speed up. so with the idea of Powershift on the old internationals I spent about 12 hours at the lathe and came up with this. A split pulley system allowing a 20% increase in speed at the pull of a lever. So that's 12 forward speeds - and another gear lever to find a place for. Of course if the system works... hopefully get get to have another look when I get home on Friday. should work, basicaly a variomatic pulley 2 HeadExam and meadowfield reacted to this Share this post Link to post Share on other sites
HeadExam 1,783 #3 Posted August 15, 2016 4 hours ago, C-101plowerpower said: should work, basicaly a variomatic pulley I wasn't aware that Wheel Horse ( a D series owner only) tractors offered a vari-drive, or are you making one adapted for them? either way GREAT job!!! 1 meadowfield reacted to this Share this post Link to post Share on other sites
meadowfield 1,900 #4 Posted August 15, 2016 Same principle as variomatic. Just two positions, low in the pulleys with no thrust on the end is low speed. High on the pulleys with them closed together is high speed. Not or aware anyone has ever done it before, though the principle is well established. DAF did it in the 50s, the system is still in use. Share this post Link to post Share on other sites
pmackellow 2,728 #5 Posted August 15, 2016 That Mark, he's a clever old Hector Share this post Link to post Share on other sites
Rocboni 257 #6 Posted August 15, 2016 That's how my lathe originally changed speeds, had one adjustable pulley opened and closed by a worm drive motor and the other is sprung, I just set it to the centre and use the inverter as the sped control motor was 3 phase. Share this post Link to post Share on other sites
slf-uk 914 #7 Posted August 15, 2016 2 hours ago, meadowfield said: Same principle as variomatic. Just two positions, low in the pulleys with no thrust on the end is low speed. High on the pulleys with them closed together is high speed. Not or aware anyone has ever done it before, though the principle is well established. DAF did it in the 50s, the system is still in use. Mark, Good work. Bolens did it with the Versa-matic drive which is on a Bolens ride-a-matic. First diff lock now Versa-matic, your WH's are getting more Bolens like by the day Iain 3 meadowfield, Triumph66 and HeadExam reacted to this Share this post Link to post Share on other sites
C-101plowerpower 548 #8 Posted August 15, 2016 Same as on the early rj 35's then 1 meadowfield reacted to this Share this post Link to post Share on other sites
ranger 373 #9 Posted August 15, 2016 Multi power! You'll have to paint the engine and wheels grey now. 1 meadowfield reacted to this Share this post Link to post Share on other sites
ranger 373 #10 Posted August 15, 2016 Some combines use the same system to alter the drum speed 1 meadowfield reacted to this Share this post Link to post Share on other sites
Chris 642 #11 Posted August 16, 2016 Mules & Gators use the same system for the drive 1 Triumph66 reacted to this Share this post Link to post Share on other sites
meadowfield 1,900 #12 Posted August 16, 2016 Just now, meadowfield said: I wasn't trying to claim it was new... My Lawnflite uses the same system to get 7 speeds... I was merely trying to squeeze another gadget - and gear lever onto Bendy. I've a thing about knobs and levers, also looking forward to printing some 12 speed stickers... 2 diggerjames and Stormin reacted to this Share this post Link to post Share on other sites
meadowfield 1,900 #13 Posted August 16, 2016 22 hours ago, C-101plowerpower said: Same as on the early rj 35's then yup Share this post Link to post Share on other sites
meadowfield 1,900 #14 Posted August 16, 2016 20 hours ago, ranger said: Multi power! You'll have to paint the engine and wheels grey now. theres an idea... Share this post Link to post Share on other sites
meadowfield 1,900 #15 Posted August 16, 2016 23 hours ago, slf-uk said: Mark, Good work. Bolens did it with the Versa-matic drive which is on a Bolens ride-a-matic. First diff lock now Versa-matic, your WH's are getting more Bolens like by the day Iain 23 hours ago, slf-uk said: apart from the colour Share this post Link to post Share on other sites
ranger 373 #16 Posted August 16, 2016 Rather than two expanding /contracting pulleys, how about using the wheelhorse pto clutch lever and gubbins, there's a good word, to push/pull the outer sheave of the pulley, and have a link to the idler/tensioner pulley to keep the belt tension right at both ratios. Share this post Link to post Share on other sites
meadowfield 1,900 #17 Posted August 16, 2016 5 minutes ago, ranger said: Rather than two expanding /contracting pulleys, how about using the wheelhorse pto lever and gubbins, there's a good word, to push/pull the outer sheave of the pulley, and have a link to the idler/tensioner pulley to keep the belt tension right at both ratios. Im only using one pulley, with the idler taking the slack. I would use the pto lever, but two three point levers have popped up there. So looking for a new home. Tempted to make it electric shift for the hell of it Share this post Link to post Share on other sites
ranger 373 #18 Posted August 16, 2016 My mate's New Holland TX42 has a spring loaded pulley, and one adjusted by a lead screw driven by a wiper motor, these are for the drum speed adjustment. Share this post Link to post Share on other sites
Triumph66 1,256 #19 Posted August 16, 2016 2 hours ago, meadowfield said: I wasn't trying to claim it was new... My Lawnflite uses the same system to get 7 speeds... I was merely trying to squeeze another gadget - and gear lever onto Bendy. I've a thing about knobs and levers, also looking forward to printing some 12 speed stickers... I am so relieved to hear that you added levers to your thing Mark that for second I thought...... . Share this post Link to post Share on other sites
Ian 2,417 #20 Posted August 18, 2016 Yet more of Mark's amazing mechanical thinking!! I just don't know how you keep coming up with all those great ideas, but keep em coming 1 meadowfield reacted to this Share this post Link to post Share on other sites
ranger 373 #21 Posted August 21, 2016 If you like lots of levers Mark, you could double up on pulleys and belts, two more levers, like a Myford ML7 lathe trilever system, just select the ratio you want by releasing one lever and pulling the other. Share this post Link to post Share on other sites
meadowfield 1,900 #22 Posted August 21, 2016 That was my plan originally, but I'm short on space... heres todays update, the two halves are spring loaded, with a custom thrust bearing and selector fork. Just the actuator to complete. Share this post Link to post Share on other sites
meadowfield 1,900 #23 Posted August 21, 2016 3 Cub Cadet, Stormin and wurzel reacted to this Share this post Link to post Share on other sites
diggerjames 543 #24 Posted August 27, 2016 Wow mark that is serious kind of cool matey brilliant 1 meadowfield reacted to this Share this post Link to post Share on other sites
meadowfield 1,900 #25 Posted September 25, 2016 Spent a bit more time, fork done. Just the actuator to sort. I've tested the pulley at fixed settings, and manually pushed the fork with the engine running. 5 nigel, ranger, Stormin and 2 others reacted to this Share this post Link to post Share on other sites
