the showman 4,074 #551 Posted August 21, 2015 I think a line-lock should be next on the list, then you could do flame burnouts 2 Ian and mowerdar reacted to this Share this post Link to post Share on other sites
Ian 2,417 #552 Posted August 25, 2015 Life is a funny old thing at times... I swapped WN's original Wh trans out with it's 5 bolt wheel fixings for a Reliant axle which is a 4 wheel bolt fitting.. Then spend loads of time converting 5 bolt wheels to 4 bolt fitting... And now I'm about to start converting the Reliant 4 bolt to fit 5 bolt wheels back on!! It's not as mad as it might sound you know.. Why??? Well it's a safety thing you see... Now WN has proved herself at going sideways (did anyone get any photo's of my BTF arena antics?), the time has come to starting thinking about something a bit faster and in a straight line.. After some careful thought the chances of going sideways at high speed is far more likely on a grass airstrip than tarmac, so with that in mind something more sticky on tarmac was found.. next door as it happens The tyres have a V speed raiting which means they are good up to 149mph!! I just need to find some better tyres for the front wheels now.. All of the above means I have some work to do to make the wheels fit, so this big old slab of steel was dug out to make a couple of wheel bolt convertors.. I see a lot of lathe work coming up in the very near future The shape eye'd of you will of noticed a something lurking in the background of the above photo.. Yep I have bought another CX/GL/silverwing engine for doing a bit of development on.. I won't give my plans away yet (those who know please keep quite if you would be so kind ) as I won't be doing anything with the engine for a long time yet, but I will say it should produce a bit more power than a standard CX/GL engine 2 S1g and Triumph66 reacted to this Share this post Link to post Share on other sites
C-101plowerpower 548 #553 Posted August 25, 2015 is that a turbo whistle i'm hearing? i do hope it is slot mags look good 3 Ian, Vinnetrow and nigel reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #554 Posted August 25, 2015 Those wheels will look good. As to the engine mods? I can only guess. 2 S1g and Ian reacted to this Share this post Link to post Share on other sites
meadowfield 1,901 #555 Posted August 25, 2015 Whoa! What next!??? 1 Ian reacted to this Share this post Link to post Share on other sites
nigel 1,881 #556 Posted August 26, 2015 could it be a V4 1 Ian reacted to this Share this post Link to post Share on other sites
Vinnetrow 129 #557 Posted August 27, 2015 thats a slab of steel if i've ever seen one 1 Ian reacted to this Share this post Link to post Share on other sites
Ian 2,417 #558 Posted August 28, 2015 And yes, it does sound good 2 Triumph66 and nigel reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #559 Posted August 28, 2015 Prefer the originals. 2 Ian and jparkes43 reacted to this Share this post Link to post Share on other sites
meadowfield 1,901 #560 Posted August 28, 2015 Prefer the originals. Me an all... 1 Ian reacted to this Share this post Link to post Share on other sites
C-101plowerpower 548 #561 Posted August 28, 2015 Prefer the originals. same, would like to see some stacks tho 1 Ian reacted to this Share this post Link to post Share on other sites
Ian 2,417 #562 Posted August 29, 2015 is that a turbo whistle i'm hearing? i do hope it is slot mags look good A turbo whistle would be nice Koen.. Those wheels will look good. As to the engine mods? I can only guess. I quite like the wheels too Norm, it would be good to find a mini matching pair for the front.. Whoa! What next!??? Your have to wait and see Mark. could it be a V4 No chance thats a slab of steel if i've ever seen one Yeah it is a heavy old lump of steel Max. It was twice the size when I found it years ago! Share this post Link to post Share on other sites
Ian 2,417 #563 Posted August 29, 2015 Prefer the originals. Me an all... same, would like to see some stacks tho You don't like them?? What's up with you all? They are great for keep ears warm Don't worry guys, those pipes were only put on like that for some experimentation.. I just posted the photo's to raise a few eyebrows The old exhaust system certainly caught a few people eye, but for me it did have a few problems. The shape of the down pipes didn't look that good where I had to extend them, the end cans made it look like someone had just bolted on a bike exhaust in the only place iit would fit, and the cans are far to restrictive in the flow department! Oh, and it sounded a bit tame! So yesterday out came the grinder and welder for operation "cut n shut" on the old exhuast sytem that came from the CX trike that Nigel and I broke up many months ago.. For me the shape of the downpipes make it look almost like a "factory" system.. Well, as factory as you can get for a bike engine stuffed in a Wheel Horse Both pipes need to be fully welded and cleaned up, then on with the black high heat paint all over.. Heat wrap for the down pipes and I have some honeycombe ally sheet to make some covers for the cans, put a bit of bling back.. But most important the system is a lot more free flowing, which is just what I need for the next stage.. 2 nigel and Vinnetrow reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #564 Posted August 29, 2015 For the black on the exhaust, Ian. Try that BBQ spray paint. Very high temp' resistant. That what I've used on the Black Horses engine and exhaust. 1 Ian reacted to this Share this post Link to post Share on other sites
Ian 2,417 #565 Posted August 30, 2015 I use spray on paint made for wood burning stoves which I expect is the same stuff as your BBQ paint Norm, just with a different label Share this post Link to post Share on other sites
Ian 2,417 #566 Posted September 1, 2015 The state of WN by the end of the day!! I think this may of had something to do with it 5 Alan, Stormin, nigel and 2 others reacted to this Share this post Link to post Share on other sites
nigel 1,881 #567 Posted September 1, 2015 got to be the best video yet it must be cos you used a realy realy good cameraman this time who did"nt mind geting covered in mud and soaked to the skin 1 Ian reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #568 Posted September 1, 2015 Who was that then? 1 Ian reacted to this Share this post Link to post Share on other sites
meadowfield 1,901 #569 Posted September 1, 2015 That looks like a lot of fun was had! 1 Ian reacted to this Share this post Link to post Share on other sites
pmackellow 2,738 #570 Posted September 1, 2015 Mad buggers :thumbs: 1 Ian reacted to this Share this post Link to post Share on other sites
Ian 2,417 #571 Posted September 1, 2015 got to be the best video yet it must be cos you used a realy realy good cameraman this time who did"nt mind geting covered in mud and soaked to the skin You didn't get soaked to the skin, I might of splashed you a little when driving past Who was that then? I'm not quite sure who it was, but they had managed to work out when the camera is recording or not this time That looks like a lot of fun was had! It certainly was Mad buggers :thumbs: I see no reason to argue with you about that Paul Share this post Link to post Share on other sites
Ian 2,417 #572 Posted September 12, 2015 Morning all, my back has kinda put me out of action for a while, so only a small update as it's all I've managed. Now.. A couple of people have told me I'm mad for making my own wheel PCD adaptors and I should just buy some!! All I can say to that is I'm making them because I can All it's costing me is time... Lot's and lot's of time! Starting with a slightly heavy 40mm thick square of steel. The center has been marked with a punch and a circle drawn so I know where to slice the corners off. This is a bit hard to see but here's my workings out to see if the wheel PCD adaptors could actually be made and the two PCD's didn't clash! As always when trying to get a 4 bolt PCD inside a 5 bolt PCD somewhere two of the bolt/stud holes are going to be close! They get even closer when you put a socket on the wheel nut! If your confused it may help if I mention that the small circle next to the socket is where a stud will be for bolt the new wheels onto. And the wheel nuts for the Reliant axle will be countersunk so there is no wheel/stud/nut clearance problems.. Once the corners were sliced off the slab went on the lathe. One side was faced off and a couple of grooves cut to mark out the PCD's before I started boring out the center. Once the center was bored out I turned the slab around to start on the other side. Just about on the size limit for my lathe here! If the diameter been a 1/4 inch wider I wouldn't of been able to get a cutting tool on to make the slab round! I'm just glad that after 8 years of owning the lathe I managed to work out how to bolt on a bracket and some cogs to give me power feed up and down the bed! It does make lathe work a bit boring but at least I only have to turn the handles half as much 4 Stormin, Triumph66, nigel and 1 other reacted to this Share this post Link to post Share on other sites
Triumph66 1,256 #573 Posted September 12, 2015 Great video Ian (and Nigel) and again your workmanship is inspiring. 1 Ian reacted to this Share this post Link to post Share on other sites
Ian 2,417 #574 Posted September 13, 2015 Great video Ian (and Nigel) and again your workmanship is inspiring. Thanks mate 1 Triumph66 reacted to this Share this post Link to post Share on other sites
Ian 2,417 #575 Posted September 18, 2015 Only a very small update as not much has been happening on this project.. As much as I love my old Southbend lathe it was struggling with the large slab of steel so I put it on my Monoturn lathe. The drill chuck is only there to stop the slab from flying across the workshop should it break loose! As nice as it looks it is way too heavy and would act like a flywheel on the wheels, so I need to find a way of cutting it in half to make 2 thinner wheel thingys or turn 1/2 inch off it's width on the lathe! 1 Vinnetrow reacted to this Share this post Link to post Share on other sites
