Anglo Traction 998 #326 Posted June 9, 2015 Stickers applied at Newby Hall courtesy of Mark. I also added a little something I picked up at Newby, to the right side of the fender. Photo tomorrow. Stickers look good Norm. Did Mark make them with Chrome/Silver?. You Teaser.......making us wait Share this post Link to post Share on other sites
meadowfield 1,900 #327 Posted June 9, 2015 Looking good, here's one I took. Yes Richard, they are chrome and laminated. Look great, but expensive to make. I think the effect is worth it though. Share this post Link to post Share on other sites
Stormin 4,458 #328 Posted June 9, 2015 I'll take some more sticker photo's tomorrow. I didn't mean to tease, Richard. Went out to take a photo, but someone had put the Spitfire in the way. Share this post Link to post Share on other sites
bowtiebutler956 166 #329 Posted June 9, 2015 There is nothing that brings out the finished product better than a fresh set of decals. Looks Great! Matt Share this post Link to post Share on other sites
Stormin 4,458 #330 Posted June 10, 2015 Photo's as promised. 1 nigel reacted to this Share this post Link to post Share on other sites
Anglo Traction 998 #331 Posted June 10, 2015 I'll take some more sticker photo's tomorrow. I didn't mean to tease, Richard. Went out to take a photo, but someone had put the Spitfire in the way. .................Wonder how many Pilots have said that in the past?. Very nice Norm. Like the Sandwich Box ! ......Can't be for Tools, you shouldn't need any after that Rebuild 1 nigel reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #332 Posted June 10, 2015 Going to put a mouse trap in it at the Silloth Vintage Rally, Richard. See if I can catch any fiddling fingers. 1 Alan reacted to this Share this post Link to post Share on other sites
the showman 4,074 #333 Posted June 11, 2015 I never got a Round-up sticker Share this post Link to post Share on other sites
Stormin 4,458 #334 Posted June 11, 2015 All together. AHHH! Share this post Link to post Share on other sites
Stormin 4,458 #335 Posted June 28, 2015 Managed to get a bit of workshop time today and got some bit jobs done on the Black Horse. (1) Clutch pedal rod adjuster nut freed off. Pedal doesn't need pressing as far forward now. (2) Slight play in right rear hub taken out. About 6 thou difference in hub bore and drive shaft diam. Sorted by use of hammer and centre punch to inside of hub. Crude but effective. Nice and tight now. (3) New gaiter fitted to bottom of gear lever. (4) Stop made and fitted to prevent brake pedal from coming to far back. (5) Is on going. Cleaning up a pair of scooter split rim wheels I got at Newby Hall. These are just right for fitting to the front with tri ribs on. Goodness knows what they've been painted with, but it's like concrete. Ready to paint now, after some filler is applied to the rather corroded insides. (6) Started to clean up the front tachomatic. BTW. The little tool box, along with a second, is an MF item. 3 nigel, S1g and ranger reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #336 Posted July 7, 2015 Afore mentioned wheels primed. Should have taken a before photo. Look a bit better, eh! Chris? 2 bowtiebutler956 and S1g reacted to this Share this post Link to post Share on other sites
ranger 373 #337 Posted July 7, 2015 Regarding a bit of play on hubs / shafts, if you have a decent lathe you could try 'knurling' the shaft to slightly increase it's diameter and also the rough finish gives a bit more grip. I used to do this to piston skirts on the old British bikes to cut down on piston slap ( 40 years ago ) when they were a bit worn. 1 S1g reacted to this Share this post Link to post Share on other sites
the showman 4,074 #338 Posted July 7, 2015 They look better Norm, you've made a good job Share this post Link to post Share on other sites
Ian 2,417 #339 Posted July 8, 2015 I'm guessing you have a wheel hub conversion planned Norm looking at those wheels.. The silver decals and black paint look great by the way Share this post Link to post Share on other sites
Stormin 4,458 #340 Posted July 8, 2015 Your right Ian. Just need to find some suitable hubs or make my own. Re-fitted the newly painted front and centre tachomatics today. Who knows, I may need them for Rural Past Times. I'd best get the rear one done as well. Plus lift cable. Share this post Link to post Share on other sites
C-101plowerpower 548 #341 Posted July 8, 2015 wont hups off of a gt 14 or the like work? those are 4bolt right? Share this post Link to post Share on other sites
Stormin 4,458 #342 Posted July 8, 2015 I've no idea and I don't have any, Koen. Suspect the spindles will be different anyway. Share this post Link to post Share on other sites
C-101plowerpower 548 #343 Posted July 8, 2015 I've no idea and I don't have any, Koen. Suspect the spindles will be different anyway. oh wait those are fronts arent they? then scratch that idea, i was thinking they were rears Share this post Link to post Share on other sites
meadowfield 1,900 #344 Posted July 8, 2015 Plus GT14 hubs are like rocking horse poo.... Try northern tool or somewhere for the hubs Norm. There's a few people do them. It's easy to turn the inside of this new shaft down and weld over the old stub axle. Theres a thread over on redsquare by calling.... Share this post Link to post Share on other sites
C-101plowerpower 548 #345 Posted July 8, 2015 don't know what size the spindles are but here's a thread on RS http://www.wheelhorseforum.com/topic/57457-how-to-trailer-hub-conversionupgrade-for-520h/ Share this post Link to post Share on other sites
Anglo Traction 998 #346 Posted July 8, 2015 If you want help from someone who has done this Mod here in UK, then send kpthorsefan a PM (last on here in April). He used UK sourced Trailer Hubs, not sure if the PCD is the same as on Scooter Rims. His excellent Thread on RS was way back in 2010/11 I believe, but when I last looked, I think the pics links had dropped out. You'd need to fire up the Lathe though Norm!..........Go for it. 1 bowtiebutler956 reacted to this Share this post Link to post Share on other sites
ranger 373 #347 Posted July 9, 2015 What PCD are the wheels Norm, I used JD mower deck spindles for my C121 front hubs. I'm sure I have some more, I think the pcd of these is around 100mm / 4" the bearing size is 3/4" so they go straight on. You can alter the track by just turning them round. if you want to try them, PM me and I'll send you a couple. Doug Share this post Link to post Share on other sites
Stormin 4,458 #348 Posted July 9, 2015 They look good Doug. But I'm not sure the hub OD will fit inside the dish of my wheels. PCD on the scooter wheels is 2-3/4". Centre hole in the wheel is 2-1/8". Share this post Link to post Share on other sites
Stormin 4,458 #349 Posted July 14, 2015 Bit the bullet today and bought some hubs, bearings etc. Spent the afternoon boring out the wheel centres and re-drilling the stud holes. Now all I need now are wheel spindles. Forgot about them. 2 the showman and slf-uk reacted to this Share this post Link to post Share on other sites
the showman 4,074 #350 Posted July 14, 2015 Did you do any photos Norm Share this post Link to post Share on other sites
